Ifs
Old Feb 14, 2008 | 08:49 AM
sleep_deprived129's Avatar
sleep_deprived129
Ifs
I was thinkin about puttin an IFS system in my 70 F-100. How hard would this be? Would I need to take anything apart to do the install other than stuff like the front clip?
Also, I eventually plan to lift the truck, is this possible with an IFS?
Old Feb 14, 2008 | 09:42 AM
80demoace's Avatar
80demoace
Ifs???
If your truck is 2wd you already have IFS. If its 4x4 WHY. Everyone I know swaps out the ifs on newer trucks to a solid axle.
Old Feb 14, 2008 | 11:01 AM
xlt70black's Avatar
xlt70black
Looking at your gallery pictures it's a 2 wheel drive you already have I.F.S.
Old Feb 14, 2008 | 11:38 AM
shift1313's Avatar
shift1313
if your talking about using a ford ttb 4x4 setup i wouldnt waste the time. It gives a nice ride on the road but if you plan on lifting it you mine as well go with a solid axle. You can get maybe 2-3" out of a ttb without serious camber problems but then you have to start getting fabricated axle pivot mounts and longer arms with build it caster.
you do technically have IFS but there are many different IFS systems out there. Can you elaborate one what your looking to do or what you want out of the swap?
Old Feb 14, 2008 | 09:55 PM
sleep_deprived129
I was really jus lookn to get somethin that'll get rid of those damn i-beams, is there a way to swap it out for a solid axle(or whatever it'd be called...jus a solid beam goin across basically), or what other options do I ave for what I want to do
Old Feb 15, 2008 | 06:00 AM
shift1313's Avatar
shift1313
anything is possible but im failing to see what you want. Do you just not like the look of the I beam setup on there now? Im sure there is an upper/lower A arm setup out there that can be converted over but nothing off hand ive seen thats a bolt in job.
Old Feb 15, 2008 | 08:25 AM
sleep_deprived129
I just know that the I-beams will be a pain when I go to lift the truck, which I do plan to do at some point.
Old Feb 15, 2008 | 11:35 AM
shift1313's Avatar
shift1313
IFS severly limit the lift capabilities. i would think you would be better off with the long swing of the stock setup then converting to something else. are you going to covert it to 4x4 at the same time? how much of a lift are you looking at?
Old Feb 15, 2008 | 04:11 PM
boo-yaa138's Avatar
boo-yaa138
autofab in california makes a really nice i beam lift for these truck. you should check out there website autofab.com
Old Feb 15, 2008 | 08:48 PM
427SOHC's Avatar
427SOHC
I think what you are looking for is what I used under my 79 F100, I agree with you on those evil twins under the front what a P.O.S. suspension in my opinion. If you look at my gallery you can see the Fatman Fabrication IFS under mine, it is still in the construction phase, the addition of the Lincoln Mark 8 4.6 liter engine has added to the build time.
The Fatman IFS was pretty much straight forward and the engineering was already worked out, it was a little time consuming and is a weld in kit. If you can attend the 2008 F100 Supernationals in Knoxville, TN this May FATMANS will have several kits on display for you to check out. Or go to www.fatmanfab.com
You can also check out MARZ68, he was custom building and bolt in IFS and has a thread already started showing the progress, the link to the thread is listed below.
https://www.ford-trucks.com/forums/6...am-trucks.html
Rudy
cdl2374
78
Aug 19, 2024 09:47 PM
StatikPulse
16
Jan 30, 2015 01:08 AM
Shawn 82
Sep 2, 2014 08:12 AM
hoprob
Mar 22, 2012 06:30 PM
mrsillman
Dec 4, 2007 09:45 AM
