camber bushing question
Old Feb 13, 2008 | 06:11 PM
mike330's Avatar
mike330
I recently installed new front springs on my 96 f150 4x4, They were the ones that are 2in. taller I know need to replace the camber bushing with the adjustable ones. Does anyone know which ones I would need? I know Rock auto has them as well as bronco grave yard. Im just not sure what I need.
Thanks
Old Feb 13, 2008 | 09:15 PM
vman's Avatar
vman
You won't know until you take it to a get a front end alignment and they can see how many degrees it's off.That's why some places sell them them in multiple packs.One side may take a dfferent degree than the other.
Old Feb 13, 2008 | 09:36 PM
ubereal2's Avatar
ubereal2
VMAN is dead right. You need a good alignment shop to measure the caster and camber. Camber will also effect the toe when you change it. You can also kill you're caster, wich won't wear a tire, but can give you a pull.
get it aligned.
Old Feb 14, 2008 | 04:58 AM
mike330's Avatar
mike330
I just came from the shop and they told me It was fine the way it was but the wheels are still \ / . They had the replacements for 2 wheel drive and told me to find out which ones could fix it. I guess Ill be going back. Can these be picked up at most parts stores? I know Moog makes them
Old Feb 14, 2008 | 05:00 AM
jr32560's Avatar
jr32560
the shop wants you to find the parts???
Old Feb 14, 2008 | 05:37 AM
mike330's Avatar
mike330
Thats right. I told them about the adjustable bushings and they said to get the prt number for the ones I need and they can get them.
The problem is there arent any shops that hadle lifted trucks around here.
