navigation system in 04 expedition
Old Feb 13, 2008 | 03:57 PM
sassy57's Avatar
sassy57
Thanks in advance for taking the time to read this. I have a 2004 eb expedition with factory navigation. The display screen has suddenly stopped working. The screen is just black on one side and blue on the other. Anybody have any ideas what the problem can be???? The radio works fine but you cant see what station your on or see the clock or anything else!!! HELP
Old Feb 13, 2008 | 07:05 PM
madsonp's Avatar
madsonp
I'm not sure about your specific system but some of these have a small reset button on them. You might check your owners manual to see if this is mentioned anywhere, if not you could probably pull it out and disconnect then reconnect the harness to it and reset it that way and see what happens.
Old Feb 13, 2008 | 08:19 PM
madsonp's Avatar
madsonp
If you can't get it working, I came across a used replacement if you want to go that route.
http://cgi.ebay.com/ebaymotors/04-05-Ford-Expedition-Factory-Navigation-GPS-CD-Radio_W0QQcmdZViewItemQQ_trksidZp1713Q2em153Q2el12 62QQcategoryZ38653QQihZ009QQitemZ190198461597
Old Feb 13, 2008 | 08:34 PM
madsonp's Avatar
madsonp
Actually pulling the correct fuse would have the same affect and would be easier. Don't know what I was thinking earlier, I guess I just like pulling stuff.
Old Feb 15, 2008 | 01:43 PM
sassy57's Avatar
sassy57
pulled fuses and still no luck, however that did work the last time this happened. also tried disconnect battery to try to reset to no avail. Guess we have to go to the dealer although I was trying to avoid that.
Old Feb 19, 2008 | 12:00 PM
alwaysfords41's Avatar
alwaysfords41
Mine intermittantly does this, I reload the nav CD's and it seems to correct it for a while.
Old Feb 19, 2008 | 04:21 PM
sassy57's Avatar
sassy57
I tried that too!! Maybe Ill try to put in a different one then put back the one I usually use. It wont hurt right!!!
