Oil Line Leak
Old Feb 13, 2008 | 03:29 PM
dartol's Avatar
dartol
Oil Line Leak
It looks like I have an oil line leak from the line on the top right of the engine on my '02 7.3L. The outside of the turbo is kinda gunked up from where oil sprays up on it. The leak is small, but enough to be annoying. It looks pretty simple to change out this hose, but I figured I should ask before I start. Has anyone here replaced the hose and is there anything special I should be aware of? Maybe it is just the fitting on the block side?
Any help is appreciated.
Darren
Old Feb 13, 2008 | 06:53 PM
F350-6's Avatar
F350-6
Are you referring to the HPOP lines?
Old Feb 14, 2008 | 07:38 AM
dartol's Avatar
dartol
I don't really know what it is, but it feeds into the block kind of under the turbo. Looks like a high pressure line... flexible braided stainless if I remember right.
Darren
Old Feb 14, 2008 | 07:41 AM
1996pwrstrk's Avatar
1996pwrstrk
Can you take take some pictures and post them ,that would help a lot.
Old Feb 14, 2008 | 07:52 AM
dartol's Avatar
dartol
Good idea, I will do that. Thanks!
Darren
Old Feb 18, 2008 | 06:54 PM
dartol's Avatar
dartol
OK, here are some pictures, any help is appreciated!
Looks like the offending part may be the brass fitting feeding into the block in this picture: HPOP line?
Thanks!
Darren
Old Feb 19, 2008 | 11:35 AM
dartol's Avatar
dartol
Humm, no one seen this before? Now I am getting worried...
Darren
Old Feb 19, 2008 | 06:58 PM
dartol's Avatar
dartol
OK last bump, I promise... LOL
My plan is to clean the engine really well and then see if I can figure out where it is coming from. Will Simple Green cut through this much sludge? From what I have been reading, it looks like that line I suspect is the HPOP line where it goes into the driver's side of the engine. Is there an o-ring there too?
I am not losing a lot of oil, just enough to leave spots in the driveway and obviously make the top of the engine nasty!
Darren
Darren
Old Feb 19, 2008 | 07:44 PM
F350-6's Avatar
F350-6
Simple green ought to help. Make sure the boot off the turbo is tight. Then try tightening up the line with a wrench first. I had a leak on the other head in one of my 02's that was fixed by just tightening it up.
Good luck.
Old Feb 19, 2008 | 11:23 PM
1996pwrstrk
It might take a few shots to get it clean don't use a pressure washer just use your good ol garden hose and rinse that valley out really good . Then start hunting I would put a wrench to both oil lines and all the plugs and go from there.
Old Feb 19, 2008 | 11:38 PM
younggunbuck's Avatar
younggunbuck
sounds like the problem i had
I just took my truck to the guy that i bought it off because of a oil leek coming down the back side and he checked it out and said all he had to do was tighten the fittings to those hoses
Old Feb 20, 2008 | 12:40 AM
griff64's Avatar
griff64
Hi, yes there are o-rings on each end of that hose and if you search HPOP on here you will get more info on them. Check out dieselorings.com they have a set of 4 for $3.50. Hope this helps, Dave
Old Feb 20, 2008 | 02:26 AM
AustinS's Avatar
AustinS
I second dieselorings.com. You'll get the right viton o-rings, cheap, and fast.
Austin
Old Feb 20, 2008 | 06:21 AM
dartol's Avatar
dartol
Thanks all! Looks like I need to get dirty this weekend...
Darren
