I have a 2001 F250 4x4- I went out last night and it looks like the 4- wheel drive doesn't work. A few months ago - one of the vacuum hoses was leaking in the front so I fixed that and then it worked- Now when I shift (SOTF)- the light comes on (I hear the Thump from the front end) but there does not appear to be power to the front wheels.... thoughts?
If you don't know for sure the front is locked in, do this. Turn your 4x4 on and turn your wheel while moving slow and see if you get the binding for the front end.
How hard is it to manually lock the hubs?? they don't seem too easy to budge
This is what I am doing this weekend. They need to be worked every once and a while. I work my auto 4x4 once a month. I have no problems right now. I am doing this for maintanance. http://guzzle.rbmicro.com/allube.html
vacuum pump? I did not think these trucks had a vac pump, I thought it got the main vacuum from the intake
either way, ill bet its the hubs, if the vacuum has a leak, you should be able to tell by other means and i doubt the solenoid goes bad that easily... if it is a bad solenoid - i got an extra with the connector on both sides of it - i pulled it out of my truck
vacuum pump? I did not think these trucks had a vac pump, I thought it got the main vacuum from the intake.....
You never said whether you have a diesel or a gas truck..... if you have a gasser, then you're correct; it runs off intake manifold vacuum. Intake manifold vacuum is darn hard to come by if you have a diesel, though, since there's no throttle... therefore, diesels have an electrically driven vacuum pump.
Real trucks don't have sparkplugs.....
No actually the original poster never said what they have...
I assumed he had a gasser...? But maybe not - in that case it can be the vac pump. But I will have to read up on the diesels - they have an intake dont they? They must have a throttle - how else do you modulate the amount of fuel? I dont know the diesels that well at all as you can see...
And it doesn't need spark plugs to be a real truck, it just needs plugs to be quiet and smell better then a refinery
In common usage, they are said to have a throttle.... but what they really have is a fuel metering control.
To be anally technical, a throttle restricts the intake air (if it has port injection or direct injection) or it restricts the incoming air/fuel mixture (if it has throttle body injection or a carburetor). Without some means of resticting the intake, you technically don't have a throttle.
