plug recomendation
Old Feb 12, 2008 | 11:18 PM
Smaug's Avatar
Smaug
plug recomendation
Motor is a 289 w/ 10:1 compression, World Products Windsor heads, Edlebrock RPM Performer intake, MSD 6A box, Ford Motorsports coil, Accel spiral 8mm wires and Mallory unilite distributor. It has Autolite platinum AP25 plugs w/ a .060 gap. What plugs and gap do you guys recomend?
Old Feb 13, 2008 | 01:42 PM
Broken40's Avatar
Broken40
With those kinds of upgrades and performance parts i would got with diamond fire plugs.
Old Feb 14, 2008 | 09:06 PM
Smaug's Avatar
Smaug
Thanks!!!!
Old Feb 14, 2008 | 09:24 PM
Beanscoot's Avatar
Beanscoot
So the "Diamond Fire Sparkplug" is the new "Splitfire"?
Don't forget to magnetize the gas.
Old Feb 15, 2008 | 02:28 PM
Broken40's Avatar
Broken40
Have a gander i think you will like:
http://www.supertruckusa.com/products/55114_106.htm
If i posted useful to you please let me know...thank you.
Old Feb 15, 2008 | 09:51 PM
Beanscoot's Avatar
Beanscoot
Thanks, I had already read that incredible information. It says the plugs may reduce fuel consumption up to 13% and may increase power up to 12%.
Remember those little propellers you could put in the air intake stream?
Polonium tipped spark plugs?
Magic pills a driver put in the fuel tank?
Intake manifold gaskets with little screens?
I do want to believe, but every time I buy into the new miracle product it seems to be a bust. But hey, maybe this time...
Old Feb 16, 2008 | 03:37 PM
Broken40's Avatar
Broken40
on the spark plugs yes, i actually know from experiance with those..i've never heard of the "magic pills" lol. give me more info lol.
Old Feb 18, 2008 | 11:43 AM
ssidney's Avatar
ssidney
I had a stock 289 4bbl 10:1, it ran best with motorcraft....don't forget Ford built some high com. engines and always used motorcraft or autolite
Old Feb 20, 2008 | 10:35 PM
Smaug's Avatar
Smaug
I got the Autolite AP25s. I was wondering if I would get a recomendation for a hotter or colder plug or maybe non plats.
Old Feb 20, 2008 | 11:37 PM
ssidney's Avatar
ssidney
look at the insulator, longer is hotter
Old Feb 21, 2008 | 01:27 AM
Beanscoot's Avatar
Beanscoot
I checked my Autolite catalogue heat range section, and it shows 23 as coldest, 26 hottest. Autolite's numbering system seems pretty incomprehensible though, for other styles of plugs the hotter plugs have lower numbers.
