Need Lift!
bought it with a 3" body lift but looking for about 6" suspension lift. up to 8"
please link me to either some decent kits or other ways to lift it.
also with only lifting 6" do i need to worry about pinoin angle and steering and brakelines and stuff?
ill take all the info i can get.
any cheap lifts or other ways to lift it without a kit or something?
But buy there more expensive versions , cause you will need longer brake lines and a pittman / idler arm drops. Longer springs and shocks.
Some kits do not come with these needed extras.
Check E-bay
4 inch lift all you change is suspension and pitman arm up front
6 inch lift suspension, driveshaft, and brake line extensions
most kits come with springs, but read fine print
skyjacker is good so is superlift, rough country, and procomp
i ordered mine off summitracing.com they have everything except rough country there
http://motorhaven.autoanything.com/suspension-systems/61A2650A0A0.aspx
