Offroad & 4x4
zero rate leaf spring
Old Feb 19, 2008 | 06:47 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
Heres the deal if you offset. You have to have the bolt that goes through the leaf pack. Then youd have to have another bolt in the hole in which you want the rear to go on. Looks that you have to use 2 bolts if you want to off set the rear.
Old Feb 19, 2008 | 06:48 PM
chrono4's Avatar
chrono4
The locator pin is the long bolt with the round head. Plus, the blocks can only go one way, because they have a chamfer on one side so you dont get stress risers in the leafs under compression. I'm still not seeing how it could work as they have it designed. It would work, just not how they have it made.
Old Feb 19, 2008 | 07:02 PM
crazyredneckanyhow
I think i have it figured out. You have to put the bolt up through the center hole whereas the relief is pointing down and the other two up. Then put the centerpinin the offset hole of your choice.
Old Feb 19, 2008 | 07:14 PM
chrono4's Avatar
chrono4
Ah ok, so it just wouldnt work right as only a lift block. Makes sense now.
Old Feb 19, 2008 | 07:18 PM
kjett's Avatar
kjett
Sure it would, you just neet to use the center hole with the center pin with the relief turned upwards. The other bolt wouldn't be used.
Old Feb 19, 2008 | 07:35 PM
chrono4's Avatar
chrono4
But they're not made to work that way. The side with the rounded corners is supposed to go up, so it doesnt stress the leaves.
Old Feb 19, 2008 | 07:40 PM
kjett's Avatar
kjett
right, and the counter sink for the center hole would be on top. You just need to run the long pin up from the bottom, put a nut in the recess between the block and spring, then continue that same pin (in other words don't cut it) on up through the leaves with a final nut on top tightning the whole pack and block together.
Old Feb 19, 2008 | 07:41 PM
crazyredneckanyhow
Ok gotcha. The center is for the centerpin and as stated the rounded edges go up. Then the siler bolt go through one of the offset holes into the leaf pack. Thus offsetting the springs on the rear not the rear on the springs if that makes sense
Old Feb 19, 2008 | 07:44 PM
kjett's Avatar
kjett
Just go back and re-read the description it says:
To use the offset, you bolt the leaf to your spring using one of the offset holes and cut the center pin off to bolt into the leaf in the center hole. This will move your axle forward or backward 1" or 1.5" depending on which hole you use and which way you mount the leaf.
To mount the leaf centered on the spring, you simply run the full length center pin through the center hole of the leaf and through the pin hole in the spring pack.
And there ya have it....
Old Feb 19, 2008 | 07:45 PM
crazyredneckanyhow
Check out unrulee gallery. Ya put the center pin through the center hole and ct it way short so the nut on it sets in the counter sink. Then you use the silver bolt to go through one of the other countersunk parts depending on the 1" or 1.5" offset. Then that makes the centerpin stick down like it should and the silver bolt head hidden. So actually the block is offset from the center of the springs
Old Feb 19, 2008 | 07:46 PM
crazyredneckanyhow
But we are talking about using it to offset the rearend not just using it for an added 1" of lift
Old Feb 19, 2008 | 07:47 PM
kjett's Avatar
kjett
At 1st we were, but Chrono asked about using it as a regular lift block.
Old Feb 19, 2008 | 07:50 PM
  #28
crazyredneckanyhow
oh ok sorry. I was wondering because i could use them and be able to use 80- front lift kit on my 78/9
Old Feb 19, 2008 | 07:52 PM
  #29
kjett's Avatar
kjett
Should work, just do the offset thing like it says in the destructions
Old Feb 19, 2008 | 07:55 PM
  #30
chrono4's Avatar
chrono4
I don't intend on using them as a 1 inch block, I was just trying to understand it all in my head. All nice and clear now, dont know what was so difficult but hey, I'm hard headed. Thanks guys.
