Sponsored by: Real Truck
19.2 Tires
Old Feb 12, 2008 | 06:10 PM
j_lauer's Avatar
j_lauer
19.2 Tires
I am interested in the 285/70R19.5 wheels from Rickson Truck. They are a bit pricey, but will be worth the money if I'm able to make them last till the end.
I want to buy a 5 tire set, but need to know if the new size will fit in the original spare spot.
Tires are listed as 35.4" tall. I have seen other fit a 35" in the original spot, but not sure if the 19.5 rim will make a difference.
If it doesn't fit and I have to stick with the original spare, what things do I need to worry about if I have to use it with the 19.5's?
Tires are going on an 06 350 6.0 CC LB SRW.
Thanks,
Jeremy
Old Feb 12, 2008 | 10:45 PM
thedaddycat's Avatar
thedaddycat
Some of these trucks come with 20" wheels so I don't think it would be a problem. I'm sure if you contact Rickson they will be able to tell you, they must have had a bunch of trucks that got matching spares.
I've looked into them too but since I have a '03 with leaf springs I don't know if the 285s will rub on the springs. I was thinking maybe the 265s which are in the 34.5" range. I wish someone made a 265/85R16 or 285/85R16 tire...
fifty-two_f1
15
Apr 1, 2014 01:22 AM
larryejoh
Aug 11, 2011 09:28 AM
Brown Falcon
Jun 14, 2010 03:10 PM
parkland
17
Jan 26, 2010 06:14 PM
John2Thomas
Aug 7, 2006 05:11 PM
