5.0 swap
Old Feb 12, 2008 | 05:31 PM
mongoose289's Avatar
mongoose289
5.0 swap
Im doing a 5.0 swap in a 86 rarnger 2.9 liter.Will the 5.0 weigh the front down enough to where i will problems with the alignment?
Old Feb 12, 2008 | 06:15 PM
mongoose289
Thanks for the info
Old Feb 12, 2008 | 09:49 PM
projectnitemare's Avatar
projectnitemare
I had zero alignment problems putting a 351W into my 88. It lowered the front about an inch with the stock 88 springs. If you either replace the springs with new, or use springs from a 4.0 supercab you will settle even less. You won't have any problems as long as you don't have alignment problems now.
Matt
Old Feb 13, 2008 | 04:08 AM
1949f1's Avatar
1949f1
keep us posted on your progress,i have a 86 that i am thinking about doing the swap in.
Old Mar 5, 2008 | 06:07 PM
mongoose289
I put the engine and tranny in it last weekend it sits about where it was before.i still have alot to do before its running but its looking good so far. i will try to post a couple of pics this weekend
Old Mar 9, 2008 | 04:04 PM
mongoose289
i went to put in my headers and they didnt fit. does anyone know of headers that will fit the gt40p heads in a 86 4x4?
Old Mar 9, 2008 | 04:13 PM
mineral723's Avatar
mineral723
I was under the assumption that you have to use shorty headers and put them in place before setting the engine, then bolt them on when the engine is in place... if that makes sense. That's just what I've been told, haven't actually done the 5.0 swap yet.
Old Mar 9, 2008 | 04:27 PM
mongoose289
i would be able to get them in place but on the drivers side the spark plugs hit the header when its in place
Old Mar 9, 2008 | 05:30 PM
mongoose289
This is where i am at now. its starting to come along
Old Mar 9, 2008 | 09:59 PM
5.0B2's Avatar
5.0B2
I used the 1996-97 Explorer 5.0 tube manifolds on my '84 B2
Old Mar 10, 2008 | 04:58 PM
mongoose289
did you have the gt40 or gt40p heads
Old Mar 10, 2008 | 09:10 PM
5.0B2's Avatar
5.0B2
I used the complete gt40p motor.
Old Mar 11, 2008 | 04:33 AM
mongoose289
i ordered some for stock manifolds for the 98-01 explorer hopefully they work
the heads i have are from a 2000
Old Mar 11, 2008 | 11:20 AM
Flexfuel-Dave's Avatar
Flexfuel-Dave
Is it that the headers didn’t fit to the heads or the headers would have bolted but you had interference inside the engine compartment?
The GT40P heads use a specific exhaust manifold no matter what vehicle the motor goes into. I believe the spark plugs are at different angles.
The stock Explorer/Mountaineer manifolds should work. Aftermarket headers are available too.
Old Mar 11, 2008 | 02:38 PM
mongoose289
the headers wouldnt bolt to the head. if i used diferent heads they would have worked fine.
do you know of any perfomance headers that will fit in the truck
