Carb Spacers
Old Jan 13, 2003 | 12:58 PM
Jay_1964_F100's Avatar
Jay_1964_F100
Carb Spacers
I'm running a stock intake and carb on my 400, and I presently have my EGR valve plated off. I would like to eliminate the EGR spacer and replace it with a phenolic spacer. I found some through Canton Racing Products, but the 2 options are for Holley carbs or for Rochester carbs. Which one has the same stud mounts as the Motorcraft 2150???
Do all 2 bbl carbs have the same stud locations?
Any help would be appreciated!!
Thanks,
Jay
Old Jan 13, 2003 | 03:41 PM
Coondawg's Avatar
Coondawg
Carb Spacers
Howdy,
I once replaced the Motorcraft 2V carb on my truck with a Holley 2V 500cfm carb. The Ford and Holley bolt patterns are the same.
You will have to replace the studs with taller ones if you use a really tall spacer.
Old Jan 14, 2003 | 06:00 AM
Jay_1964_F100
Carb Spacers
Coondawg,
Thanks for the info, I figured it might be the Holley.
Jay
Old Jan 14, 2003 | 03:06 PM
shazam's Avatar
shazam
Carb Spacers
