Timing problem
Old Feb 12, 2008 | 05:05 PM
spectackler1's Avatar
spectackler1
Timing problem
84F150 with a 351W- truck slightly hesitates, but the timing mark is 180 degrees out from the timing bracket. (it's showing up on the bottom of the harmonic balancer when the #1 cylinder fires) Please help. Thanks
Old Feb 12, 2008 | 05:16 PM
scrapyardking's Avatar
scrapyardking
Make shure you have your light cliped onto the right wire. And disconect the vacume advance.
Old Feb 12, 2008 | 06:11 PM
Franklin2's Avatar
Franklin2
The correct wire is the front passenger side wire.
