subwoofer deciding!!!
Old Feb 11, 2008 | 11:11 PM
XolieX's Avatar
XolieX
i am looking at alot of everybody else's combo and it all looks great! however i am debating between a sealed dual 10 box and use my mono block memphis 500 watt amp or use the ALL MIGHTY JL AUDIO stealth boxes. JL makes great stuff and is pricy though. however the box is wired for 4ohm and 300 watts, if i had to power that correctly the only thing i got to power that decently at 4ohm is a 2 channel EFX at 250 watts (maybe). or rewire the sub (if i could) to a 1ohm stable but i am then putting out 500watts to a 300 watt speaker!
its a 10w3v2 by the way!
any input on a subwoofer combo!
my two top choices right are " use my two 10w1's subwoofers in a supercrew and still use my memphis mono block"
or
buy the expensive JL audio stealth box (pricey) and use my efx 2 channel amp!
alot of people say JL audio is one of the Best overall audio company. i am thinking long run, i might as well go all the way and go JL audio insted of buying something then finally deciding to go JL audio.
i am getting tired of changing stuff around alot to find something bettter. i want the best at the beginning!
thanks guys
