rough idle and lean code
Old Feb 11, 2008 | 06:55 PM
green250's Avatar
green250
Exclamation rough idle and lean code
I have a 2000 f250 superduty 4x4 5.4 liter.At idle it runs rough and misses.I am throwing a system lean bank 1 code.The rpms fluctuate up and down.While driving it still has a slight hesitstion and power is down with poor gas mileage.I have changed all fuel injectors,cleaned maf,replaced pcv and checked hose for crack/leak.I Also replaced the fuel presure regulator.Fuel pressure is about 38# not running.The coils have been replaced with accels about 7 months ago.just changed the plugs about 2 months ago but going to do it again.Any advice anyone has will be greatly appreciated.Ive already done searches and havent found anything to cure my truck yet.Thanks in advance to any suggestions.
Old Feb 11, 2008 | 11:06 PM
Fordfreak_24's Avatar
Fordfreak_24
my truck did something similar. there is a plug on the bottom of air filter housing. mine had poped off and was sucking in unmetered air. i had to permitex mine on to get it to stay. that might be something that you'll want to check. good luck
Old Feb 12, 2008 | 03:57 AM
green250's Avatar
green250
thanks,i looked and everything is ok with the air filter.
Old Feb 17, 2008 | 09:20 PM
wilkinda's Avatar
wilkinda
Mine did the same thing and it was the PCV on the right bank. Changed it out and the problem went away...
Old Feb 17, 2008 | 10:31 PM
LxMan1's Avatar
LxMan1
Check the PCV hose elbows. Especially the one connected to the rear of the intake manifold.
Old Mar 11, 2008 | 09:47 PM
FatDutchMn's Avatar
FatDutchMn
rough idle
Will this rough idle from the PCV have an effect on gas mileage?
Old Mar 12, 2008 | 10:35 AM
projectSHO89's Avatar
projectSHO89
If you have a vacuum leak, one of the most common symptoms is a rough idle (if the leak is large enough).
Steve
Old Jun 20, 2022 | 07:41 AM
Yorkkidinda831's Avatar
Yorkkidinda831
6th Gear
SAME PROBLEM
Any solution??
For months I’ve had random misfire problems and engine too lean codes. I changed coils and plugs and it was better for a day before engine light came back on and symptoms returned. Rough bouncing idle, lagging power especially from 40mph to 60 and uphill, mpg loss, light will flash when trying to accelerate at higher speeds. Changed PCV valve and hoses after mechanic found small vac leak. STILL same symptoms persist. Mechanic supposedly checked MAF sensor and other easily accessible potential suspects. Idk what to do. I’m novice and am trying to learn everything i can to save my mobility. Is it wiring to coils? Fuel injectors? Fuel filter? 2 mechanics so far have tried and failed to find solution. Please be patient with my ignorance. Thanks for your time
2003 Navigator 2WD 160,000m 5.4L
Old Jul 14, 2025 | 06:40 PM
F-250 eng-unupgradium's Avatar
3rd Gear
Rough idle issue
Originally Posted by Yorkkidinda831
Any solution??
did you figure out issue? I’m chasing so bad idk. 01 f250 5.4. Had lean code but just rebuilt motor because any mechanic I told about oil in coolant and blew radiator connection said. It was the oil cooler. Not head gaskets. All this work and it fires but rough idle soon as it starts warming. Also backfires out exhaust and very low power trying to drive. Left bank didn’t seem to be firing.
MartinTravels
May 31, 2014 06:52 AM
JET1274
15
Feb 28, 2014 09:55 AM
Trado11
Apr 9, 2013 07:02 PM
Brutl_Force
1997 - 2003 F150
17
Aug 20, 2011 03:44 AM
ruskc1
1997 - 2003 F150
Feb 28, 2010 06:54 AM
