Truck not running.......
Old Feb 11, 2008 | 04:27 PM
Todd525's Avatar
Todd525
So I havent had a problem with the fuel filter, usually you get a little low on power and then it shuts down. I was on the way home yesterday after having to drive thru about a foot of water when the temp dropped to about 6 degrees. The fuel filter light came on, 2 minutes later truck would not run. So I got up today and replaced fuel filter and it ran for about 2 minutes in idle, then went back the same sceanrio, it died. So I guess I am wondering this. did I freeze something up from the water??? Or did this Bosch fuel pump take a crap on me? When I opened the filter housing up, it had fuel to JUST the BOTTOm of the stand pipe. SO I guess its either not getting it from the lift pump, or I have a frozen clog diezxel gell or whatever you wanna call it. 8 inches of snow forecasted here, so I think I am just going to stick it in the shop with heat and see what happens in 24 hours to see if it was just gelled. Any thoughts????
Old Feb 11, 2008 | 04:36 PM
Action4478's Avatar
Action4478
Unhook a fuel line try running air through it ?..
Have you tried switching tanks ?...
Selector valve ?....
Old Feb 11, 2008 | 04:38 PM
Todd525's Avatar
Todd525
Havent done anything other than the fuel filter so far. Its just been to dar cold, and I have to get it over to my shop bere I try anything else. I almost bet its froze the more that I think about it. 48 hours of heat will do her some good I think.
Old Feb 11, 2008 | 04:44 PM
Action4478's Avatar
Action4478
Definately....
Old Feb 11, 2008 | 05:23 PM
Cuda_jim's Avatar
Cuda_jim
WAG; Maybe you got the CPS wet?
Never mind I just re-read your post........
Old Feb 11, 2008 | 06:09 PM
Todd525's Avatar
Todd525
Well, got it over to the shop a few minutes ago, turned the heat on, I could have swore I heard the truck sigh.........LOL
I hate having it acorss town, but just cant get it into my garage. I have three snowmobiles, my Yamaha Rhino with snow plow, two dirtbikes, and both street bikes in it for the winter. I think this breakdown taught me a few valuable lessons.
1. Dont drive thru water if its only 6 degrees out, just turn around and say that you cant make it to work.
2. I might want to try to sell some of my stuff so I can get my truck into my home garage.
3. I might want to look for a house in the country that has enough room so I dont have to sell my stuff and can still get my truck into my own garage.
4. I am glad I own my own shop, or lessons two and three would be a pressing issue.....
LOL
Thanks for all the ideas guys, and I only have one real question.
Where is the selector valve actually located at? I assume that sever icing could get it stuck in limbo somehow since I assume it has a selinoid on it correct? I never tried switching tanks as my back tank is almost empty, I might give that a try on wednesday as I am sure we wont be open tomorrow with all the ice and snow that is starting to fall.
Thanks again
Todd
