460 struggle
Old Feb 11, 2008 | 06:42 AM
dj250's Avatar
dj250
460 struggle
Truck idles fine. Runs pretty good until you put it down. It has more power at 1/2 throttle other than full. Starts to shake like if the tire was skipping or the engine has a rev limiter above 3,500rpms, because it won't even accelerate until it swiches gears and goes to a lower rpm.. I was thinking fuel filter maybe. No check engine light.
Old Feb 11, 2008 | 08:04 AM
tfowler306's Avatar
tfowler306
check your spark plugs and wires. sounds like missfire under load.
Old Feb 13, 2008 | 06:47 PM
stngh8r's Avatar
stngh8r
My first thought was fuel filter too. Also, As stated above, I would rule out the ignition.
