2002 7.3 engine
Old Feb 10, 2008 | 10:57 PM
mrwrench's Avatar
mrwrench
2002 7.3 engine
I will parting out a 2002 powerstroke engine.
I can trade some parts for 2005 grille bumper or wheels.
Old Feb 10, 2008 | 10:59 PM
Snowbunny's Avatar
Snowbunny
Why are you parting it out?
Old Feb 10, 2008 | 11:04 PM
mrwrench's Avatar
mrwrench
Broken rod
any idea how to fix it?
Old Feb 10, 2008 | 11:09 PM
Snowbunny's Avatar
Snowbunny
Did it punch a hole through the block?
Old Feb 10, 2008 | 11:22 PM
mrwrench's Avatar
mrwrench
the holes are in oil pan
Old Feb 10, 2008 | 11:34 PM
Snowbunny's Avatar
Snowbunny
Have you dropped the pan yet? Or pulled the heads?
Old Feb 10, 2008 | 11:46 PM
mrwrench's Avatar
mrwrench
No , I just pull it out of the truck. everything is on the engine. I can see the broken rod trough the holes.
Old Feb 10, 2008 | 11:48 PM
Snowbunny's Avatar
Snowbunny
I see,,, How many miles are on it?
Old Feb 10, 2008 | 11:50 PM
mrwrench's Avatar
mrwrench
around 90 k
Old Feb 10, 2008 | 11:52 PM
Snowbunny's Avatar
Snowbunny
What kind of mods had you done? Did you chip it?
Old Feb 10, 2008 | 11:54 PM
mrwrench's Avatar
mrwrench
No chip- standart
Old Feb 11, 2008 | 12:05 AM
Snowbunny's Avatar
Snowbunny
Well, if it was only the rod and oil pan, it could be rebuilt. It would be a major overhaul, but as long as the block and the crank are good, it can be done. It may be cheaper and definitely faster to just drop another one in.
But, I would be more concerned about why the piston seized in the first place, which is usually why the rods break. Was it due for an oil change? What kind of oil do you use? What were you doing when it happened?
Old Feb 11, 2008 | 12:19 AM
mrwrench's Avatar
mrwrench
Hummm.... I should take off the head and check.
Old Feb 11, 2008 | 12:29 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
If you do part it out I would want some stuff off of it
Old Feb 11, 2008 | 12:37 AM
SolidGround's Avatar
SolidGround
Originally Posted by mrwrench
Broken rod
Cummins swap!
