1960 engine swap
Old Feb 10, 2008 | 07:49 PM
terry lucas's Avatar
terry lucas
1960 engine swap
i need information on placing a 351 w in to a 1960 ford p.u. with an auto trans....
Old Feb 10, 2008 | 09:41 PM
vbarker's Avatar
vbarker
Thumbs up
It can be done, I just happen to have a motor mount kit and Trans x-member (brand new) that I'not going to be using. Staying with the stock y-block (292)
Vern
Old Feb 11, 2008 | 07:34 PM
terry lucas
Hi Vern: Thanks For The Info.i Need To Know Were To Set The Engine ,what To Do About The Cross Member,the One Under The Cab? Thanks Again Terry
Old Feb 11, 2008 | 07:39 PM
vbarker's Avatar
vbarker
Thumbs up
Terry, Placement will be drop it and adjust,,, not sure. The factory x-member from looking at mine wil more than likely have to come out (grinding off the rivets). I haven't done that type of conversion so keep asking on the forum, one of these great guys will more than likely have the answer.
Old Feb 12, 2008 | 03:07 PM
bememe's Avatar
bememe
I had to remove the existing crossmember you're talking about for my 5.0 liter and AOD to fit. I modified a mustang trans crossmember so I could use the stock X pipe. Also integrated engine mounts in with MII crossmember, unfortunately that doesn't help you much.
Old Feb 12, 2008 | 08:11 PM
terry lucas
Hi Bememe: Thanks Fore The Help.
DouglasF350
Apr 3, 2007 09:12 PM
whomrig
Mar 18, 2002 06:54 PM
MARC
Apr 25, 2001 09:07 PM
barry
Apr 5, 2001 01:08 AM
