FPR Shim
Old Feb 10, 2008 | 07:26 PM
nhill2090's Avatar
nhill2090
FPR Shim
Tonight, despite freezing tempartures, i decided to shim my FPR. I used the #4 washer method, used in this link. . . http://superdutydiesel.com/wiki/tiki...p?articleId=26
however, i could not get the washers to seat right in the brass sleeve at all. instead i used the washers to shim the FPR cap. I used 3 washers and filed them down until they fit flush in the cap. I have not bought supplies to hook up the fuel pressure gauge so I'm not sure where that put me as far as pressure. Does the thickness of the 3 #2 washers i used even compare to the hex head bolt many people are using to shim theirs?
I need to get a fuel pressure gauge to see where im at for sure but i was lookign for smarter peoples opinions
Old Feb 10, 2008 | 08:50 PM
medhvac's Avatar
medhvac
well ill bump this and maybe someone will help u!
Old Feb 10, 2008 | 09:20 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Well, I have not used the washer method as I felt better about the #4 40 hex head. At any rate you really need to be prepared with a gauge to see what it does. That is before and after the mod. Right now you have no idea what it is doing, and that write-up was a bit lacking in pics. The manual says excessive pressure will result in reduced pump life which means early failure. At least get a gauge on it.
Old Feb 10, 2008 | 09:32 PM
PaysonPSD's Avatar
PaysonPSD
You might want to keep an eye out for fuel leaks until you get a pressure gauge.
Old Feb 10, 2008 | 09:33 PM
nhill2090's Avatar
nhill2090
yes i checked for fuel leaks before and after a test drive, and a fuel pressure gauge will be going on ASAP, i may re-do it with the 4-40 hex head
Old Feb 10, 2008 | 09:40 PM
PaysonPSD's Avatar
PaysonPSD
Probably better to go with a single screw shim than a 2 to 4 piece shim. Less to fuss with. If you know about the #4/40 screw than you have most likely seen this but I'll post this link anyway http://www.puredieselpower.com/Tech/...tor%20Shim.pdf
Old Feb 10, 2008 | 10:15 PM
nhill2090's Avatar
nhill2090
thanks for the link robin
Old Feb 10, 2008 | 10:20 PM
PaysonPSD's Avatar
PaysonPSD
Glad to do it Nic. I like the PDF write ups. Easy to save and they're only a click away.
Old Feb 10, 2008 | 10:30 PM
rbaker6336's Avatar
rbaker6336
PDF does store easier,I covert almost all my saves to PDF
Old Feb 10, 2008 | 10:38 PM
nhill2090's Avatar
nhill2090
That is a good idea. Most of the time i just put the links in my favorites
Old Feb 10, 2008 | 10:42 PM
PaysonPSD's Avatar
PaysonPSD
I should get the complete PDF program. All I have is the read and no write. But at least it lets me save PDF format. I usually have to copy and paste to
wordpad or if it has pictures than I copy and paste to a word proceesor.
Old Feb 10, 2008 | 10:50 PM
PaysonPSD's Avatar
PaysonPSD
Do both, then you can post a link to help someone and save the info to your computer in case the link or the site it was on goes away.
Old Feb 10, 2008 | 10:51 PM
rbaker6336's Avatar
rbaker6336
there is a nice small program I use and it's free,check out http://www.cutepdf.com/Products/CutePDF/writer.asp
Old Feb 10, 2008 | 10:59 PM
nhill2090's Avatar
nhill2090
that is a good point, i may start doing that
Old Feb 10, 2008 | 11:00 PM
Tenn01PSD350
Nice link Ray, thanks for sharing and reps your way.
