Will a WW hurt performance
Feb 10, 2008 | 12:44 PM
I tow alot,usually 20,000 to 25,000 on the trailer and have some surge.I have read up on the WW and the ats housing.I know that from the sounds of it the ats housing is the best choice but I may have to go with the WW for now.Will I see any performance loss?
Feb 10, 2008 | 01:04 PM
Do you have the early or late 99? If you have an early 99 you already have the WW.
Feb 10, 2008 | 01:06 PM
Feb 10, 2008 | 01:25 PM
you may losse very little on top..what you do loose on top..you will gain at the bottom end...if your stock wheel is good..save it and when you get the ATS..put the stock wheel back in..
Feb 10, 2008 | 01:29 PM
Ok then that will be ordered tomm.
Feb 10, 2008 | 01:34 PM
Feb 10, 2008 | 01:41 PM
Wasn't planning on removing the turbo.Unless I should and replace the orings?
Feb 10, 2008 | 01:45 PM
if it dont leak.. dont worry...but could come in handy to have a set of orings in the glove box
Feb 10, 2008 | 01:49 PM
Was going to order the trans cooler 4739 from them so I might as well get the wheel there too.
Feb 10, 2008 | 04:34 PM
Thats funny,cause i loost some bottom end when i changed my ww.
Wayne64SS
Nov 5, 2010 08:39 AM
Sparkplugless
20
Mar 3, 2010 09:44 AM
makomaker
35
Apr 29, 2008 07:57 AM
tholt34
20
Oct 25, 2007 09:44 PM
RAMPAGE_F350
78
Aug 13, 2006 11:11 PM
