popped a plug... blew up outta the head!
#46
Another Victim
My son just blew out a plug on 02 supecab with 4.6L. Can you usually just put anti-seize on a new plug, put the plug into the head, and torque the new plug ? Do you need to add a heli-coil,anti-seize, and the new plug ? I hadn't seen the truck yet. Should be towed home sometime tonight. This truck has had numerous problems. From the rear brakes/emergency brakes, clutch/slave, and head gasket. Nothing but headaches. The other two ford pickups in the family have had no major problems. Does this have to go to the dealer to be fixed ?
Thanks
Thanks
#48
Yes this a 4.6L 5Speed standard 02 CrewCab. Like you, I thought only the 5.4. The dealer replaced the head gaskets about 2 months ago. I'm going to let them deal with the problem. Won't mind working on the truck but it never breaks down close by.
I hadn't seen the truck but from the description the coil and the plug are history. I've wrenched every truck I've owned include my present truck a 97 Lariat 4.6L 4x4 short bed. Never seen this many problems with one truck. I'm beginning to think it may be the driver !
#49
#50
Just got the word from the dealer. $400 to put in a heli-coil, COP, and spark plug. They claim this happens to high mileage Ford engines. (This truck has 70,000 miles) They claim this happens on 4.6L and 5.4L. This truck is going up for sale this weekend. Way to many problems. Looks like the other plugs could blow out at any time from what the dealer told my son. I've had Ford trucks for over 30 years. That's it for me !
My buddy who owns a junk yard and will have nothing to do with Ford trucks build after 1996. This guy had nothing but Ford trucks dating back to the flat-head V8 days. I understand what he's talking about. I hope I can get a few more years out of my 97 F150 with 64,000 miles.
#51
#52
#53
with my luck, i'll have misfires when i'm done. this truck has been so reliable.
#54
#55
#57
#58
Look at this:
TSB
07-21-2 4.6L 2V, 5.4L 2V, OR 6.8L 2V - SPARK PLUG THREAD REPAIR PROCEDURE - NOT COVERED UNDER NEW VEHICLE LIMITED WARRANTY
Publication Date: October 17, 2007
FORD: 1997 Thunderbird
1997-2004 Mustang
1997-2008 Crown Victoria
1997-1999 F-250 Light Duty
1997-2004 Expedition
1997-2008 E-Series, F-150
1998-2004 F-53 Motorhome Chassis, F-Super Duty
2001-2005 Excursion
2002-2006 Explorer
LINCOLN: 1997-2007 Town Car
1998-1999 Navigator
MERCURY: 1997 Cougar
1997-2008 Grand Marquis
2002-2006 Mountaineer
This article supersedes TSB 07-15-2 to update the vehicle model years.
ISSUE:
Some 1997-2008 vehicles equipped with a 4.6L 2V, 5.4L 2V, or 6.8L 2V engine and aluminum cylinder heads may experience a spark plug port with stripped or missing threads.
ACTION:
Follow the Service Procedure steps to correct the condition for non warrantable repairs.
SERVICE PROCEDURE
Ford Motor Company now authorizes LOCK-N-STITCH aluminum insert and tool kit as a proper repair procedure.
Follow the procedure included in the tool kit for using the tools and inserts. Tool kits and inserts can be ordered from Rotunda by calling 1-800-Rotunda (768-8632). Choose option two (2), part number 302-00001.
NOTE: FORD MOTOR COMPANY HAS DETERMINED THAT REPAIRS MADE WITH THESE ALUMINUM INSERTS AND LOCK-N-STITCH TOOLS DO NOT AFFECT THE HEAT TRANSFER FUNCTION BETWEEN THE SPARK PLUG AND THE CYLINDER HEAD.
NOTE: THIS PROCEDURE IS NOT AUTHORIZED AS A FORD WARRANTY REPAIR. FOR VEHICLES WITHIN WARRANTY, REPLACEMENT OF THE CYLINDER HEAD IS RECOMMENDED.
NOTE: THIS IS THE ONLY FORD AUTHORIZED PROCEDURE FOR SPARK PLUG THREAD REPAIRS.
NOTE: THIS PROCEDURE IS AUTHORIZED FOR ESP REPAIRS AND RETAIL REPAIRS.
WARRANTY STATUS:
Information Only - Not Warrantable
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2007 Ford Motor Company
TSB
1997-2004 Mustang
2001-2005 Excursion
2002-2006 Explorer
1998-1999 Navigator
ISSUE:
ACTION:
SERVICE PROCEDURE
WARRANTY STATUS:
#59
I just love that part.....for "warranty" purposes, it's recommended the head is replaced.....but if it's into the ESP (costing thousands for some, $1,800 for me)
patrickm84
1997-2006 Expedition & Navigator
09-25-2013 11:06 PM
KC Excursion
2004 - 2008 F150
10-06-2012 06:30 PM
sfc2001
44
07-10-2011 07:14 PM
Manipulator
Modular V8 (4.6L, 5.4L)
02-08-2009 07:36 PM
