want more power
Old Feb 9, 2008 | 08:52 PM
FreakinSweet351's Avatar
FreakinSweet351
want more power
Hey everyone, i wanna get more power out of my 351 cleveland without tearing it down and doing the bottom end. The motor has fresh rebuilt 2v heads with a 4v edelbrock intake and a 600 cfm edelbrock performer carb and a 1 inch spacer. Its got a .494 lift cam, and a double roller timing set. I also put a set of headers on it. Any tips on how to get more power out of it would be nice.
Old Feb 10, 2008 | 11:28 AM
hollenjoe's Avatar
hollenjoe
boost your compression ratio ( mill your heads 0.0025 if you dont want to disasemble your bottom end), get a bigger cam, and a bigger carb..... whats your scr?
Old Feb 10, 2008 | 11:37 AM
FreakinSweet351
What is scr?
Old Feb 10, 2008 | 11:42 AM
hollenjoe's Avatar
hollenjoe
static compression ratio, what kind of pistons are you using, overbore?
Old Feb 10, 2008 | 11:43 AM
FreakinSweet351
They are the stock pistons 8.0:1 compression
Old Feb 10, 2008 | 11:49 AM
hollenjoe's Avatar
hollenjoe
uuuu, gota change that, you could get 8.5 to 1 by milling the heads and get good power by the bigger cam and carb, but gas consumption and torque will be critical. you should think bout new flat tops over 40 pistons for that engine, or get aussie heads to boost your scr.
Just by boosting your scr to 9 - 9.5 youll notice great imrove in power....
