Sponsored by: Auxito
97 f 150 Door Hinge
Old Jan 7, 2002 | 10:22 AM
jerry11's Avatar
jerry11
Post 97 f 150 Door Hinge
I have a 97 f 150 and always have had a popping noise when opening and closing the driver side door. The door is now having more trouble closing. The hinge will need to be replace, I believe. Is this difficult?
Old Jan 7, 2002 | 05:02 PM
FTE Ken's Avatar
FTE Ken
97 f 150 Door Hinge
Yes, its hard. Aligning the door can be difficult without the proper equipment. Door lift equipment is made for this type of stuff though a transmission jack would probably work if you had a friend helping....
Old Jan 9, 2002 | 10:51 AM
jerry11's Avatar
jerry11
97 f 150 Door Hinge
Thanks, Just received a call from the dealership apparently the adjustment arm in the middle of the door punched a hole through the body of the truck, the noise explaned, and now welding needs to be done. Ask why, and is unknown.
Old Jan 9, 2002 | 10:55 AM
94van's Avatar
94van
97 f 150 Door Hinge
