02 mountaineer using oil
Old Feb 9, 2008 | 02:04 PM
mf8tel's Avatar
mf8tel
02 mount. has 110k miles and is using 3 quarts of oil between oil changes which i change every 5000 miles no towing, plowing, or offroading, no spots in the driveway any ideas why this is happening?
Old Feb 9, 2008 | 02:12 PM
aquanaut20's Avatar
aquanaut20
First check if you are leaking rings and valve seals. Compression/leakdown test. Check colour of plugs while you have them out.
Is you PCV stuck, it will suck oil into intake manifold
Ther may be no spots on driveway, but check undercarriage for oil slick from blowback(airstreaam)
BTW ford states 1 Qt per 3000, is acceptable.
Old Feb 9, 2008 | 02:15 PM
mf8tel's Avatar
mf8tel
Changed plugs at 100k and they all looked great. No smoke from the pipe and i cannot locate the PCV valve and i have searched i could use some direction on its location.
Old Feb 9, 2008 | 04:54 PM
mf8tel's Avatar
mf8tel
Old Feb 25, 2008 | 07:06 AM
CMOS's Avatar
CMOS
What engine do you have?
CMOS
Jesser02EX
Aug 19, 2016 02:35 PM
02GrayPowerStroke
1997 - 2003 F150
Jun 23, 2015 11:18 PM
bradcdavis00
Oil & Lubrication
Sep 15, 2005 09:18 PM
KenFromNorCA
Mar 15, 2005 05:42 PM
DRT BOY
Oil & Lubrication
Oct 13, 2004 11:38 PM
