timing not advancing
Old Feb 9, 2008 | 09:29 AM
dtford's Avatar
dtford
I have a 1990 f150 I-6 5speed 80k. the truck starts to lose power around 2000 rpm, check codes , nothing shows up comes back with the pass code 11. put timing light on truck and accelerate the timing is not advancing.Spout connector is pluged and does check good. truck runs the same with in or out. Looks like a possible pcm replacement but wanting to here input before I go buy I new one.
Old Feb 9, 2008 | 01:59 PM
mortis08's Avatar
mortis08
You need to UNPLUG the spout when setting timing. When my pcm went out it only ran with the spout unplugged. Goodluck!
Old Feb 9, 2008 | 03:11 PM
EPNCSU2006's Avatar
EPNCSU2006
Check for continuity in the SPOUT connector itself and also between the TFI module and the computer. If sounds like either the SPOUT connector itself is not working, or there is a bad connection along that wire between the ignition module and the computer. Bill (subford) may come along with a wiring diagram for you if you're patient...
Old Feb 9, 2008 | 05:40 PM
subford's Avatar
subford
1990 4.9L (VIN Y) engine.
Here is the Ignition Diagram for system "D" Push Start:
PCM # FUNCTION Wire Color
16 IGN GND ORANGE/red
56 PIP A GRAY/orange
36 SPOUT PINK
4 IDM TAN/yellow
ICM # FUCTION Wire Color
6 PIP GRAY/orange
5 SPOUT PINK
4 START RED/blue
3 ICM POWER RED/LT green
2 COIL TACH TAN/yellow
1 GND BLACK/LT green
Old Feb 10, 2008 | 03:53 PM
dtford's Avatar
dtford
the spout connector is working, I set timing and when I plug the spout back in the timing advance about 5* I also did the timing advance test through the computer where it will advance the timing for 2 minutes. it did advance about 20* but only for about 45 sec not 2 minutes then it settle back to where it started, but it still will not advance when you increase the RPM but it will move for a second on deceleration and sometimes on acceleration but it always settle back to where it at idle no matter if you hold RPM up.
Old Feb 11, 2008 | 05:16 PM
EPNCSU2006's Avatar
EPNCSU2006
Are you checking it while the computer is still in the self-test mode?
TramCommon
Nov 25, 2016 07:28 AM
kfcoltn
Aug 29, 2016 11:34 AM
henryFord460
21
Jul 1, 2016 02:40 PM
seagull369
1997 - 2003 F150
Feb 17, 2016 11:26 PM
SawZall
1997 - 2003 F150
May 2, 2006 12:55 PM
