Throttle body spacer?
Old Feb 9, 2008 | 05:18 AM
92302FREAK's Avatar
92302FREAK
Arrow Throttle body spacer?
Alright.....I was thinking about putting in a throttle body spacer plate on my 92 f150 302 to try to help get a little more response out of my gas pedal and a little better gas milage and I was wondering if anyone has already done it. If so is there anything else I would need to buy in order to put it in(i.e. throttle cable, wiring harness,ect.........)and also if I need to calibrate the computer for for the grater ammounts of air going through the manifold?
Old Feb 9, 2008 | 06:51 AM
92302FREAK's Avatar
92302FREAK
.......Anybody?
Old Feb 9, 2008 | 06:56 AM
frederic's Avatar
frederic
A throttle body spacer isn't going to increase your airflow, nor increase the power that your vehicle produces.
All they do (on EFI vehicles) is lighten your wallet.
Old Feb 9, 2008 | 07:50 AM
92302FREAK's Avatar
92302FREAK
.......Really?
Old Feb 9, 2008 | 07:51 AM
92302FREAK's Avatar
92302FREAK
So would there be any point at all to put a throttle body spacer on an EFI?
Old Feb 9, 2008 | 07:58 AM
80351's Avatar
80351
If you get one of the anodized ones it looks pretty but that's it.
For throttle response, look and see if when you push the gas pedal all the way to the floor if the butterflies are open all the way.
whowey's Avatar
whowey
You would gain a TINY bit of power... That's cause your wallet is lighter and the truck is carrying less weight.....
Old Feb 9, 2008 | 08:09 AM
92302FREAK's Avatar
92302FREAK
Then what does a throttle body spacer do for a carburated vehicle and not for an EFI vehicle?
Old Feb 9, 2008 | 08:52 AM
TheRoadVirus's Avatar
TheRoadVirus
On an EFI vehicle the injectors are injecting almost directly into the combustion chamber. On a carbed vehicle the fuel is flowing through the manifold, spacers can help with fuel atomization among other things.
Old Feb 9, 2008 | 11:25 AM
quicklook2's Avatar
quicklook2
a total waste of time and money.
asked every few months for years and always will get the same response.
Old Feb 9, 2008 | 11:43 AM
DJdemon6696's Avatar
DJdemon6696
jep... it will only help A LITTLE but!! in the 6000 7000 rpm range... so no its not worth it.. get some free flowing exhuast
Old Feb 9, 2008 | 12:15 PM
quicklook2's Avatar
quicklook2
if he puts the 5.0 in that rpm range it will "pull a skan" (grenade).
Old Feb 9, 2008 | 12:35 PM
DJdemon6696
hahah lol.....
Old Feb 9, 2008 | 04:07 PM
Big_Man_Brad's Avatar
Big_Man_Brad
Now maybe if you get a performance throttle body but not a spacer...
Old Feb 9, 2008 | 04:19 PM
quicklook2's Avatar
quicklook2
more air in and more air out is what you need.
