Broken Timing Cover - HELP!
Old Feb 8, 2008 | 10:52 AM
dkhollins's Avatar
dkhollins
HELP! I broke the timing cover on my 89 460 trying to pry the old seal out and was wondering if someone knew if one from a 96 would work on it? The casting on the 96 is F6TE-6059-GA but the Ford Dealer said they didn't see where it would cross.
Old Feb 8, 2008 | 02:16 PM
monsterbaby's Avatar
monsterbaby
yes it will, only issue is if you use the newer style on an older vehicle with the mechanical fuel pump the FI covers don't have it punched out or drilled and tapped but your 89 shouldn't have a mechanical pump anyway. You can use trhe older ones on a newer engine you just have to by a fuel pump block off plate.
hunter444
Oct 20, 2014 01:37 PM
robjs111
1978 - 1996 Big Bronco
Mar 7, 2013 11:02 PM
faycotrophyhunter
40
Jun 28, 2011 10:57 PM
Tacit_k
Feb 23, 2004 08:15 AM
