Oil pres. problem
Old Mar 13, 2001 | 10:58 PM
78bigblock's Avatar
78bigblock
Oil pres. problem
I have a 1978 Shortbox with a 460 from a lincon that seems to burn oil a bad. Now it runs smooth, seems to have good compression though i have not had it tested, yet some days the truck smells like it burns a lot of oil badly. I do have a small leak but i doubt that would do it. What could cause this other than the rings or a scratched cylinder wall?
Old Mar 14, 2001 | 09:07 AM
66_f100_460's Avatar
66_f100_460
Oil pres. problem
My 66 f-100 has a 460 and it also burns oil bad. I was told it was the valve guide seals. I haven't fixed it yet, btu I was told to put brake fluid (about half a small container) in the oil drive with it for a few days and then change the oil. It should swell the valve guide seals, and stop burning oil. It that it your problem. Hope this helps.
Old Mar 14, 2001 | 12:03 PM
TBirdGuy's Avatar
TBirdGuy
Oil pres. problem
I would strong suggest not doing that. You will cause the valve seals to swell, but you will also cause all the other seal (rear and front mains) to swell also, possibly cracking. Then you'd have a heckuva oil leak on your hands that is an incredible pain to repair. Also, there is a good possibility that you can do some bearing damage. Brake fluid is corrosive and could dissolve the precious metal away from you main and rod bearings, and THAT will only lead to even worse problems.
TBirdGuy
"Stuck with a m*par, Settle for a ch*vy, Happy with a Ford!!!!"
Old Mar 14, 2001 | 04:43 PM
78bigblock's Avatar
78bigblock
Oil pres. problem
thanx 4 all your help and the opinions. I do think that if the money allows I should build a older 429 or 460 around 1969-1972??!! I guess i will do a few thing and see what happens and then if it gets worse i will consider a rebuild or something. Thanx again!
Old Mar 15, 2001 | 09:08 AM
66_f100_460
Oil pres. problem
Thanx tbirdguy
I never even thought about that, good thing I haven't tried it yet. Sorry 78bigblock
Old Mar 15, 2001 | 06:19 PM
78bigblock's Avatar
78bigblock
Oil pres. problem
Well it is a good thing that i decided not to try it either. Oh well, no harm done.
Old Mar 15, 2001 | 08:39 PM
f10074's Avatar
f10074
Oil pres. problem
lordyfordy
3.8 & 4.2L V6
Apr 3, 2023 05:13 PM
Itch71
16
Oct 4, 2016 08:27 AM
MEL SCHLABOTNIK
Oct 7, 2015 08:47 AM
rollinblackcloud
May 12, 2013 10:55 AM
bassproguy07
Jan 23, 2006 06:50 PM
