I was told the other day by my buddy that the 85 Ford I purched last year is a heavy half F150. Is ther such a thing and if so what makes it different?
Read the GVW printed on the door jamb sticker. That will tell you what the max Gross Vehicle Weight is for that truck.
1975-1979 the F-150 was considered a heavy half. It had a higher GVW than the F-100, mainly to get around the smog requirements imposed on the lighter GVW trucks. In 1980, the GVW minimum was raised, and all F100/F150 were subject to the smog standards. By 1984, the F100 was dropped.
I thought the term "heavy half" was a chevy term?. Ford had their "lightduty" f250's, which would probably be considered the same thing.
If you have 8 lugs holding the wheels on, but do not have a large piece sticking way out the center of the rear wheels, then you have a lightduty f250.
Actually, heavy half was GMC, chevy called it "Big 10". Ford chose the F-150 as it's higher GVW 1/2T designation.
I believe the original GVW cutoff for emission standards was around 5450 LBS, hence the early F-150 had 5500 LB or higher GVW.
the 6100lb GVW F-150 is the heaviest 1/2 available at that point in time. if you look at your rear suspension there will be an extra leaf spring bolted on top of the pack and there will be a set of tabs on the frame for that spring to hit.
