Offroad & 4x4
Steering suggestions
Old Jun 12, 2008 | 12:52 PM
  #31
touchngo's Avatar
touchngo
I have the same setup as well, ranger body on fullsize chassis, plus I have an additional problem, my motor is mounted with engine plates and I use fenderwell headers, and the motor plates mount right were a stock box sits. and I would have a very hard time getting the steering shaft form the column to the box with the headers in the way, my steering shaft now JUST fits,
Old Jun 12, 2008 | 01:16 PM
  #32
kjett's Avatar
kjett
I'm looking to figure that all out too. I will have uprights headers and a 460 on motor plates. ANy issues with running the linkage between the tubes like that?
Old Jun 12, 2008 | 01:30 PM
  #33
freejay's Avatar
freejay
Originally Posted by kjett
This is basically what he has, the ram is a little diffrent though. Looks like a normal double ended hyudralic ram:
West Marine: SeaStar Hose Kits, Seal Kits, Hoses Product Display
I just didn't think a system like that would have enough pressure to turn the wheel. I don't really care about pushing rock out of the way, I just want to be able to move it when the wheels are spinning/moving.
I'd be very interested to see what kind of pressure this system would put out with no pump at all (fully manual system). It may be just what you need to steer while moving. I'm sure it would totally suck for low speed, etc. but as long as you can steer while WOT thru the pit then who cares? It would by far be the lightest, simplest to mount and just run the hoses wherever you can.
You could increase the leverage it puts on the wheels with longer steering arms if needed...
Old Jun 12, 2008 | 02:44 PM
  #34
touchngo's Avatar
touchngo
Karl, I made 8 passes on the weekend and the steering worked great, I don't see any rubbing of the shaft on the headers or the headers on the coil buckets(both spots are close,1/8" on each side)the motor plate keeps the engine from rocking in the frame. it was a pretty smooth track though
Steve
Old Jun 12, 2008 | 06:40 PM
  #35
STGFordCrazy04's Avatar
STGFordCrazy04
Originally Posted by touchngo
no offense but I dont like that. I have no reason or experience to back it up but it just doesnt look right to me. The shaft angle is pretty extreme.
thats about all Ive got.
Great build otherwise.
Old Jun 12, 2008 | 10:56 PM
  #36
touchngo's Avatar
touchngo
no offence taken, I had no real plan for the steering when I started, I took off all the stock steering to mount the motor and said (I'll worry about the steering later) when I got the motor in and the header on I didn't have much to work with, that shaft doesn't go striaght to the rack its attached with another ujoint mounted to a pill block on the frame thats attached to the stock steering shaft form the explorere that has another ujoint in it, as well as the slip yoke(as the rack is mounted on the axle)it held up fine this weekend, only time will tell
Steve
Old Jun 12, 2008 | 11:28 PM
  #37
countryboy116's Avatar
countryboy116
its definatly tight in there, never have any trouble with it hitting the headers?
Old Jun 13, 2008 | 04:24 PM
  #38
kjett's Avatar
kjett
Thats how the guy that runs the local bog has his on his s-10 blazer. From a normal standpoint, the angles are way extreme for any useful steering on the trails, but in our world of limited turning radius and quick turn steering setups, 3/4 turn of the wheel in either direction and you are turning from lock to lock, so it end up being the normal for mud racing.
Old Jun 13, 2008 | 05:50 PM
  #39
countryboy116
never thought of that, guess it would be ok for a mud racer then, anyone else watch the mud bog race on speed the other day, pretty cool
Old Jun 13, 2008 | 09:05 PM
  #40
touchngo's Avatar
touchngo
no its not ideal, but the steering did work flawlessly this weekend, 8 200' passes with no problems, mind you it was only 1 weekend, and as I stated we run straight pits with very little mud, its almost a sand or dirt drag, more then a mud drag,
Steve
Old Jun 13, 2008 | 09:51 PM
  #41
STGFordCrazy04
touchngo where are you from man? and what kind of heads are you running?
Old Jun 13, 2008 | 11:08 PM
  #42
touchngo's Avatar
touchngo
Ontario, Canada,
they're ford motorsport A460 heads
Old Jun 13, 2008 | 11:49 PM
  #43
STGFordCrazy04
I seemed like Ive seen that truck before but I guess not.
A460s = Niiiiice.
Im using TFSs.
Old Jun 14, 2008 | 09:27 AM
  #44
touchngo's Avatar
touchngo
I was at the special events Jamboree last year in Vermont with it, if you were there, got my a@$ kicked in class 3, did have a different motor then and the doors weren't lettered yet, still had fun thourgh. they wouldn't let me run class 2 because my box is just 2 box sides.
Steve
Old Jun 14, 2008 | 12:23 PM
  #45
STGFordCrazy04
no I must have you mistaken for someone else.
I always run here
Thunder Valley Motorplex
