engine harness
Old Feb 6, 2008 | 10:00 PM
Vladimir Hyde's Avatar
Vladimir Hyde
engine harness
is there a viable difference between the engine wiring harness between an 88 300 L6 and an 89 302 V8 or are they interchangeable? just out of curiosity
Old Feb 6, 2008 | 10:20 PM
jr32560's Avatar
jr32560
88-89 not sure on the 87-88 you can just unhook them at the firewall-and switch them out-may be the same on those years-subford would know if he does not chime in send him a pm
Old Feb 6, 2008 | 10:31 PM
ssidney's Avatar
ssidney
one BIG difference 6inject/8injector wiring (unless you have throttlebody)
Old Feb 14, 2008 | 09:34 AM
Vladimir Hyde
well if i were to use the 302 plus the injector wiring would it mate properly to the 300 harness? would the ecm get all wacky?
Old Feb 14, 2008 | 09:41 AM
Conanski's Avatar
Conanski
The sensors and actuators are in very different locations on the two motors, so you can't put one on the other without tearing it all apart and re-routing a bunch of stuff.
Old Feb 14, 2008 | 05:27 PM
jr32560's Avatar
jr32560
the ecm will have to be changed-does your wiring harness unbolt at the fire wall???
Old Feb 15, 2008 | 12:14 AM
Vladimir Hyde
not sure, havent looked that far into it, but i have both trucks so i could swap the harnesses too. this is mainly a hypothetical.
