Passing Emissions Trick
Old Feb 6, 2008 | 06:22 PM
Dexterwho's Avatar
Dexterwho
If you need to pass an emissions inspection and have an evap code 14443 or EGR code and have tried everything If you clear the code start your truck and drive it for 30 miles. Now heres the important part you must have the inspector run the test without shutting off the engine because once you shut it off and start it again the computer will pick up the codes. Your check engine light will come back on within 5 miles once you resart your engine but by then youve passed your inspection and your free from tickets for the next year and maybe by some luck you will have the problem fixed by next year but dont hold your breath this is a code that doesnt like to go away
wantahertzdonut
13
Jun 13, 2013 02:21 PM
D8chumley
2009 - 2014 F150
20
Apr 28, 2013 06:56 AM
BigJared
May 30, 2011 11:35 PM
blackened
1978 - 1996 Big Bronco
22
Apr 4, 2006 09:31 PM
