429 info
Old 02-11-2001, 09:47 PM
drago's Avatar
drago
drago is offline
429 info
Hey.
Could somebody that knows any information about the 429 such as hp & torque numbers, the best year, and any opinions on which is better 429 or 460 or any other news, give it to me. Any input is appreciated.
Later.
Old 02-20-2001, 06:52 PM
Heetseeker_1's Avatar
Heetseeker_1
Heetseeker_1 is offline
429 info
I like the 429. You can still find them around in the early 70's sleds and are easy to pump up. I would find a 68-71 429 because the compression ratio was up to 10.5 for the 2v and 11.0 for the 4v. The comb chamber was 75.8cc vs 91.4 for the 72. With a slightly dished piston, you can have a very streetable 9.5:1 motor. If you go with a cam much larger than stock, I would put better springs, roller rockers, hardened pushrods and guideplates in it.
I guess it depends on what you're going to use the motor for. Towing or racing around. You can improve the 460 with a set of cobra-jet heads too.
Good luck.
Old 03-30-2001, 01:58 PM
stingrayj72's Avatar
stingrayj72
stingrayj72 is offline
429 info
Dido on heetseekers info. I like the short stroke of the 429. For good power and long life go with a build up that does't exceed 5500-6500 rpm's max., especially on the longer stroke 460.
Old 03-30-2001, 07:23 PM
TBirdGuy's Avatar
TBirdGuy
TBirdGuy is offline
429 info
I have to be different. I prefer the 460. You know the saying, "No Replacement For Displacement." Really it would depend on what you are going to be doing with the motor. Towing or hauling, the added torque of a 460 would be your best bet. Racing would be the 429 because you can rev a shorter stroked motor higher than a longer one. If you just want and everyday driver that is dependable, stick with what you have.....If you have a 429 stay with it, if you have a 460 stay with it. Hope that helps.
TBirdGuy
"Stuck with a m*par, Settle for a ch*vy, Happy with a Ford!!!!"
Old 03-31-2001, 08:09 AM
jrs effie's Avatar
jrs effie
jrs effie is offline
429 info
OK heres my 2 cents, The difference between the 429 & 460 is the crank and pistons, and from what I understand that is it. Now having said that I aggree with Heetseeker in saying to stay with the 68 - 71 year model because it is a higher compression motor, and also T Bird is right too cubic inch IS HP. It does depend on what you plan to do with it,towing or crusing town lookin for camaro's to feed on. I have a 68 model 429 that is at the machine shop now getting punched .30 over and balanced with a 501 stroker kit, it will be a street truck, but you can do the same with a 460, the main thing is to match your parts and dont just go out and buy a lot of "high performance stuff" and stick it all together and hope is is what you wanted. Now I won't be towing with mine, so all I'm hoping for is to pass at least every other gas station.
Good Luck
Tommy
Old 04-02-2001, 04:38 PM
78bigblock's Avatar
78bigblock
78bigblock is offline
429 info
templeton
11-09-2021 03:01 PM
ryceman168
04-23-2014 01:39 PM
nothercrash
09-23-2010 10:43 PM
boss429
29
11-27-2003 09:26 AM
Tribal
07-04-2001 08:16 PM
Quick Reply: 429 info
