E350 460 Doner
Old Feb 6, 2008 | 05:07 PM
lampoulos's Avatar
lampoulos
E350 460 Doner
I've recently acquired a 460 and E40D out of an 89' E350 bus complete with the wire harness and ECM. I'm planning on setting it into an 86' F250 that had a 302 and AOD at one time. I can make all the mechanical changes pretty easily (oil pan, engine mounts, new radiator, etc.). I'm expecting a complete rebuild before it goes into the truck, but am unsure on the changes I'm going to have to make to the engine wiring harness for the conversion. Since there will be no emenities on this truck the a/c and smog pump are coming off along with their systems and have already decided on a new serpentine setup for it. What problems should I be looking to correct while I"m doing the build?
