The best bang for the buck is to put your money back in your pocket. There are no aftermarket intakes available for the EFI 4.9. AFAIK, there are only two that have even been prototyped and they haven't been tested yet.
What about that guy who made those "Pro-Comp Tuned" headers? The ones that looked they were made of PVC? Redneck engineering something or other. I'll bet he could fabricate a really nice equal length runner intake.
There was a fellow a while back who posted a picture of a header he claimed to have "found" on eBay. It looked terrible. He was ridiculed and never returned!
lol! i remember that! at first i said to myself "oh they dont look that bad" then i looked up hedman headers and compared.... no comparison!
Yeah theres no intake available for the 300 EFI. its already a well designed motor, theres not a whole lot you need to do to it. So take Silver Streak's advice and put it back in your pocket and save it for something worthwhile.
The EFI intake is actually quite the set up. Some have even (don't know if anyone has or not) considered using at least the lower half with a plenum on it for mounting a carb. I've been looking at that myself or even adapting a carb mount to the whole thing.
If you really want to get a little more air flow through your intake, get a throttle body off of a 302. They are identical except for the size of the inlets. I just put one on my '89 bronco. You're gonna have to do a little fab work yourself though. Nobody makes a throttle body spacer/adapter to fit a 302tb onto a 300 intake, also, you're gonna want to keep the IAC valve and the TPS off the 300, the wiring is slightly different. I may be persuaded to take mine apart so I can post some pics of the whole thing.
Have you tried it before? I didn't think so. It does actually give me a little more power, but the whole reason for trying this was to improve fuel economy, which I won't know exactly what the outcome is for a few more days when I've driven more than 60 miles and get a little more of an average figure, but it does seem to be helping there as well, I'll post more when I have the numbers. I wish I had access to a dyno tho so I could've seen what the actual numbers were before and after.
u dont see any increase in power. what u are feeling is a slight increase in throttle response because the engine is seeing more air sooner. but u are also reaching the max allowed useable air sooner as well. while it may feel like u have gained 25 RWHP, all it did was change how much air is let in at a certain throttle position. u are not letting any more air in.
Produce a dyno chart to that affect and we'll happily agree that it helped. This topic has been beaten to death on this forum. Proof of more power in the form of a dyno sheet, timeslip, etc. has been requested dozens of times and nobody will put their money where their mouth is. Until then, OI has it nailed.
Does anyone know where I can get to a Dyno around Chico, CA and how much it will cost? I don't have a lot of extra cash laying around, but I am curious to see what it's done myself and if it'll prove a point either way I'd be interested to check it out.
