I just bought a 1988 F250 w/ 460 ci engine. My oil pressure gauge goes past high when its started and stays there. I changed oil/filter and put in a new thermostat (unrelated issue). Any ideas?
I'd start with the sending unit... I've had that happen before, although not on this make/model.
Disconnect the lead. If it stays at "no pressure", that rules out a short in the wire and check out the unit next. Not sure what these cost, though. But if the actual oil pressure was really that high, there would be other symptoms
The gauge is just an idiot light. If you have at least 7 PSI, it swings to about halfway up the gauge. No pressure and it will obviously read in the red. Any other readings are the result of electrical or sender issues.
The only way to have a legit high reading is if the valve in the oil pump is messed up. Put a real gauge on there and if you still have a high reading than the oil pump needs to be replaced.
seen it happen....when people use the heaviest spring with a HV pump, usually on GM though..bypass in filter can't handle it, rev. rev. POP! (it probly is rare, but I work in an engine shop for a few years and seen all kinds of wierd things)
The high reading could also be a bad ground...the sending unti is groudned to the block by itself.....could try pulling it out cleaning the threads up real good and puttin her back in there...might solve.....you would be better off with a mechanical though anyways.....then you always know.
my 88 f150 had a ranger sending unit on it from the factory-space limitations I guess went to a mechanical and original-just re piped the connection-and hooked it all up with the correct sending unit-was like $4 in part for the piping -not including the mechanical oil gauge-you think ford could have spent an extra $4 to get the right gauge on there???
