Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
progress
Old Feb 5, 2008 | 11:28 PM
effie_man's Avatar
effie_man
progress
well i worked in the garage for quite a while today, got the new rear tires on the new rims and installed. Finished removing the old oil pan and replaced witht he new painted one. Cleaned and painted starter and flywheel cover and installed. Put together front springs with gaskets and installed bushing and painted the front axel. Looks like itll be on its own wheels tomorrow or thursday, then its time to tackle 12v conversion
Old Feb 5, 2008 | 11:30 PM
preppypyro's Avatar
preppypyro
Man you are getting a pile of work done.
Is there alot of work involved in doing the 12 v conversion? Seems to me it would be quite abit.
Old Feb 5, 2008 | 11:31 PM
Dustin1690's Avatar
Dustin1690
Right on good to hear on the progress
Old Feb 5, 2008 | 11:32 PM
Snowking's Avatar
Snowking
about 3 wire changes 3 resticters and 1 reducer, oh and change the alternator, took me a hour but then i was fiarly drunk.
Old Feb 5, 2008 | 11:33 PM
preppypyro's Avatar
preppypyro
Oh hell thats not bad at all.
Snowking's Avatar
Snowking
oh also change lightbulbs, thats a tricky one.
Old Feb 5, 2008 | 11:37 PM
effie_man's Avatar
effie_man
change bulbs, coil, alernator/generator, reistors to distributor (i got a pertronix so im good there) resistors to all guages except volt meter, voltage regulator and battery and im changing my cables too. Can change the starter too but not necesary
Old Feb 5, 2008 | 11:38 PM
Snowking's Avatar
Snowking
Don't have to change dist neither.
Old Feb 5, 2008 | 11:39 PM
effie_man's Avatar
effie_man
no just have to put a resistor to it if not upgrading, otherwise you go through points like crazy
Old Feb 5, 2008 | 11:42 PM
preppypyro's Avatar
preppypyro
Heres a kinda off topic, but kinda on topic. Can you get a upgraded distributer that doesnt use points for your truck? With going to twelve volt it might be an asset to upgrade stuff like that.
Old Feb 5, 2008 | 11:47 PM
Snowking's Avatar
Snowking
it's not necasseary from 1955 till 1972ish points were used on 12 volt, Even some 302s used points yet..
There are so many ignition systems now for Flatheads as well as any other older motor anything is readily avable for a decent price.
so in short answer Yes.
Old Feb 6, 2008 | 06:15 AM
96sherm's Avatar
96sherm
thats real good news Chris!! more pics on the way right??
Old Feb 6, 2008 | 11:53 AM
Corner Gas's Avatar
Corner Gas
That is sounding really good Chris.
Old Feb 6, 2008 | 08:40 PM
effie_man's Avatar
effie_man
petronix ignitor is what your talking about, runs around 100$ and takes 5 mins to install. Put one in mine today as a matter of fact. Its just an easy electronic ignition that deletes the points and condenser
Old Feb 6, 2008 | 09:07 PM
preppypyro's Avatar
preppypyro
Right on, I think that is a pretty handy upgrade.
