Starter
Old Feb 5, 2008 | 09:37 PM
fordf2594's Avatar
fordf2594
Starter
I was just wondering if there was a difference in a starter for a 89 and a 94 or not?? i ahve one for an 89 that will filt but i hear it's different somehow. oh and by the way it's a 5 speed truck
Old Feb 5, 2008 | 10:08 PM
quicklook2's Avatar
quicklook2
get the correct starter.
Old Feb 5, 2008 | 11:33 PM
Surge08's Avatar
Surge08
two way different trucks
Old Feb 6, 2008 | 05:15 AM
dave2's Avatar
dave2
You might try something like rockauto.com and type in both trucks to see if they show the same PN. If they look the same, have the same amount of teeth, and spin the same direction, why not?
Old Feb 6, 2008 | 09:22 PM
Old_Paint's Avatar
Old_Paint
Should be a VERY noticeable difference in the two. The '94 starter will have the "REAL" solenoid mounted right on the starter. The fender mounted relay only drives the solenoid. The '89's fender mounted relay IS the solenoid, and the starter's field coils actually engage the bendix. Look under the hood to identify what's there now. Look at the starter, and see how different it looks. If you don't see the cylindrical solenoid mounted on it with one large post and either a .250" spade connector or another smaller stud, NO, you cannot use the '94 starter. If you find a large cable going from the fender mounted relay to the starter, NO, you cannot use the '94.
Clear as mud now?
Does your 89's starter look like this:
http://www.partsamerica.com/ProductD...pe=123&PTSet=A
or does your starter look like this:
They are NOT interchangeable without some significant modifications to the primary electrical system, and I'm not sure they're mechanically the same, i.e. that the bendix does the same thing on them.
Old Feb 6, 2008 | 10:36 PM
Surge08's Avatar
Surge08
what size engine i will look it up
