Engine hoist or Front End Loader
Old Feb 5, 2008 | 11:52 AM
dreo2003's Avatar
dreo2003
Hi,
I need to do an engine swap on my truck and i was wondering if i could just use a front end loader to pull it out. i don't have a hoist so i would have to buy one but i do have a loader so can i just use that or are there complications that im not thinking about. do people do this? or should i just spend the money for a hoist? thanks.
Old Feb 5, 2008 | 12:01 PM
Animalistic's Avatar
Animalistic
I have done it with a forklift. Just get the chains in the right place. The only issue I can see with the loader is visibility. It was hard enough with the forklift. I had one guy on each side to make sure I did not rip anything apart as it was coming out. With a hoist and forklift, you have the advantage of side to side movement. If you have the backhoe attachment, you may want to use that. Hope this helps.
Old Feb 5, 2008 | 12:02 PM
ford390gashog's Avatar
ford390gashog
I had no option but to use a Cat 350 excavator on my 390 install. I would say go ahead.
Old Feb 5, 2008 | 12:23 PM
dreo2003's Avatar
dreo2003
hey thanks guys. i dont have an excavator or backhoe so there isnt much side to side movement. it does have an articulating joint for steering so that could help too.
Old Feb 5, 2008 | 01:06 PM
Animalistic
As long asa you are good at running your equipment, you should be fine. Just take it easy.
Old Feb 5, 2008 | 01:25 PM
wizzard351's Avatar
wizzard351
ive changed more engines with a tractor and loader then with a cherry picker or chain hoist. whats nice about a frontend loader once you have the engine pulled just hop on and drive away with it and you dont need to be on concrete
Old Feb 5, 2008 | 01:30 PM
dreo2003's Avatar
dreo2003
wizzard, thats a good point. the truck is parked in the mud so i was thinking that if i had to use a hoist, id probably have to pull it back with my other truck. with the loader, i can just drive off. i think you guys have convinced me to work with what i already have. i just didnt know if that would be overkill or if it could damage something.
Old Feb 5, 2008 | 03:05 PM
Animalistic
Yes this is overkill and most definately yes, you can damage something. I have run heavy equipment before and most times, you do not even feel what you damage. Take your time, watch your spotters and you should be fine. Some pictures would be a bonus
Old Feb 5, 2008 | 04:45 PM
ssidney's Avatar
ssidney
use a chain hoist or come-a-long attached to the buket of the loder...this will let you observe while you lift...gradually
Old Feb 5, 2008 | 05:20 PM
fmr9's Avatar
fmr9
ssidney beat me too it. I was going to suggest the same thing. Come along lets you ease it up real slow and don't need spotters . Once it is up and clear the loader lets you drive it off.
Good Luck Frank
Old Feb 5, 2008 | 06:33 PM
wizzard351's Avatar
wizzard351
whats a spotter? nevr used any if your careful and run back and forth and make shure EVERY thing is unhooked ya dont need nobodys help
Old Feb 6, 2008 | 12:46 PM
dreo2003's Avatar
dreo2003
Animalistic, if its pics you want then pics you shall receive.
This is the truck that i'd use to pull the engine hoist back if i decided to use one. you can see the engine in the bed.
this is the truck the engine will go into. please dont yell at me for posting in the wrong forum. you can see the front end loader in the background
this is the engine up close
side view of the engine showing the loader in the background.
thanks for all the responses so far everyone. i'll keep you posted on the status of my engine swap.
Old Feb 9, 2008 | 03:28 AM
bowhunt72's Avatar
bowhunt72
Loader should work just fine. Just be careful with your rigging and take it slow. We did this when pulling and reinstalling the engine for a 1930 Seagrave fire engine for our fire department. None of the engine hoists at the city garage would fit - it's a Continental 500+ cubic inch flathead inline six, weighing roughly 1000 pounds. So we borrowed a backhoe from out street department and used that. Go slow and take it in small steps so you can stop and check clearances frequently.
Old Feb 9, 2008 | 02:24 PM
Snowseeker's Avatar
Snowseeker
where are the pics? I have used trees in the past for doing motor swaps. lol Now I do everything off my overhead hoist.
Old Feb 9, 2008 | 06:28 PM
icrman's Avatar
icrman
I have used poles ie fresh cut scrub to make a tripod, I have used extension ladders, and since I did heavy equipment for many years I've used many various peices of that also. As well as a strong tree branch. The best ever is a nice boom truck. The most controled is to use a beam or tripod and a chain hoist.
