1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Backup (Alarm, sounder, beeper)?
Old 02-05-2008, 10:26 AM
SirHailstone's Avatar
SirHailstone
SirHailstone is offline
'07 SD - is there a wire in the harness to accomodate a backup warning device? I found a sounder that works on 12 or 24V DC but unsure about the current pull. I have a feeling it would draw too much current to tap into the standard reverse light.
Old 02-05-2008, 11:11 AM
walleyeman's Avatar
walleyeman
walleyeman is offline
If you are worried about your factory wiring, install an inline fuse holder before the backup alarm. Try a 10 amp fuse, I suspect you will be fine.
If your backup alarm draws more than that, use a relay, coil to backup lights and ground, output from trailer charge circuit to backup alarm.
Old 02-05-2008, 08:52 PM
vlietracer64's Avatar
vlietracer64
vlietracer64 is offline
You could use the Trailer reverse circuit that way if it dose blow a fuse you will not loose the trucks rev. lights seeing how most trailers do not come equiped with rev. lights.
tiger275
Electrical Systems/Wiring
07-18-2016 12:26 PM
SVT_Lover
2009 - 2014 F150
06-16-2015 12:36 PM
PRUSue
05-15-2013 10:24 PM
robert_l_ross
08-26-2012 12:56 AM
jamespud
02-28-2011 05:09 PM
Quick Reply: Backup (Alarm, sounder, beeper)?
