Backup (Alarm, sounder, beeper)?
'07 SD - is there a wire in the harness to accomodate a backup warning device? I found a sounder that works on 12 or 24V DC but unsure about the current pull. I have a feeling it would draw too much current to tap into the standard reverse light.
If your backup alarm draws more than that, use a relay, coil to backup lights and ground, output from trailer charge circuit to backup alarm. |
You could use the Trailer reverse circuit that way if it dose blow a fuse you will not loose the trucks rev. lights seeing how most trailers do not come equiped with rev. lights.
