heater woes
Old Feb 5, 2008 | 01:26 AM
The_SnowMan710's Avatar
The_SnowMan710
heater woes
ya the heater in my 81 f-150 doesn't work and i think it's in my selector valve...how do i go about changing one of these?
Old Feb 5, 2008 | 02:19 PM
Franklin2's Avatar
Franklin2
It doesn't blow air? If so, the first thing I would do is run a wire directly from the battery to the blower motor and make sure it works. Also check all the fuses.
Old Feb 5, 2008 | 03:15 PM
Piffery1's Avatar
Piffery1
Make sure the blend door (flapper inside heater box) is moving to the hot position.
Old Feb 5, 2008 | 03:34 PM
The_SnowMan710
well, it blows sometimes and doesn't others, it will get warm if the selector valve is set just right but as soon as i mess w/ it to try for, say, defrost or something, it'll never go back to heat
Old Feb 5, 2008 | 03:39 PM
Piffery1's Avatar
Piffery1
Typical of worn out selector assy.
Old Feb 5, 2008 | 03:44 PM
The_SnowMan710
that's wat i assumed but i've heard that it's all vacuum controlled so i wasn't too sure how bad this is going to suck to replace...any idea's?
Old Feb 5, 2008 | 03:46 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Heater only, or does it have A/C?
The heater control on my 1980 is messed up, and it will not change from heat to defrost. The actual control lever is behind the glovebox, and I simply open the glovebox, and operate the lever to select which function I need, be it heat, defrost or off (for the summer). My truck was an early 80, with dealer added A/C.
For the hot/cold side, the control lever is under the hood.
Note: this is for non-A/C equipped trucks, factory A/C is drasticly different.
Old Feb 5, 2008 | 03:53 PM
The_SnowMan710
crap. i have factory A/C...how screwed am i ??
Old Feb 5, 2008 | 05:55 PM
Piffery1's Avatar
Piffery1
Not to difficult to change the control--if you can find one. NAPA used to sell
them for some vehicles, I bought one for a Mopar once. I found a good one on a junker. LMC truck might have them.
Old Feb 5, 2008 | 06:30 PM
Franklin2's Avatar
Franklin2
Mine had A/C, and it was giving me problems, and I found a rotted plastic line that ran underneath the glove box. I am not sure what it did, but it seemed to fix it. Also make sure your line in the engine compartment is in good shape, and also the one that goes to the vacuum resevoir can. The line that runs by the fan area supplies vaccum for the whole system.
Old Feb 6, 2008 | 05:31 AM
srercrcr's Avatar
srercrcr
You can find the control on ebay occasionally, but it will take patience.
Old Feb 6, 2008 | 10:31 AM
The_SnowMan710
ic, i will check all of these spots, thanks guys!
