fuel pump eccentric...
Old May 14, 2001 | 02:08 AM
mike460's Avatar
mike460
i plan on using an electric fuel pump, and i know i have to use the stock mechanincal fuel pump eccentric, but do i really need the ring that surrounds it too?
mike
Old May 15, 2001 | 01:11 PM
dre's Avatar
dre
The eccentric is only to pump the mechanical pump.
block off opening with a block-off plate.
Dre'
1978 F-150, 460ci(750cfm,Edelbrock Performer,Dynomax Ceramic Coated headers,etc.)Auto-C6,3:70.1 - 9" Posi.
Old May 17, 2001 | 12:19 AM
79supercab4x4's Avatar
79supercab4x4
this may be too late...but if not, i woudl suggest installing the cam eccentric. i almost didnt on one of my vehicles because i was running an electric pump at the time but about a year later i ended up switching back to mechanical and was glad i left it. its always better safe than sorry...it woudl suck to have to pull the timing cover and all that. anyway, i dont think leaving it off would help you at all but whatever you want.
Old May 17, 2001 | 08:44 AM
dre's Avatar
dre
Good point.
That's why when you deviate from factory settings, regardless of
the settings, you need to weight the results.
Example: can I afford to continue this way if something breaks or goes wrong?. or will I have to go back to the factory settings.
If you know that there will be a chance that you will go back, then have a return route.
Dre'
Old May 17, 2001 | 09:30 AM
85351ho's Avatar
85351ho
