fuel pump
Old May 21, 2001 | 02:25 AM
mask's Avatar
mask
fuel pump
I´ve got a 460 stock with a holley750 vac.
is the stock mechanical fuelpump a little smal or maybe mine is bad so the engine runs leean on higher rpms?
When i go with full trottle it starts to missfire after abaout
4sec. could that be the problem?
In that case what do you suggests.
Mask
Old May 22, 2001 | 12:28 PM
proud owner's Avatar
proud owner
fuel pump
May very well be the fuel pump.. Also check the jetting on the carb and the carb passages. Something may be clogged and restricting full flow at full throttle.
Also, check timing. If retarded, will cause that. Check that the vacuum line to dist is hooked up to correct port on Holley. Check the distributor itself. make sure the advance is working. I know, cause MY holley did that too! Check all this before fuel pump.
J/.c
1965 Ford Galaxie 500 (okay, so not quite a truck)
460/C6 transplant @ 389hp/491 lb.ft.
14.29@103.8, 13-14 mpg heheheheheh
Old May 23, 2001 | 01:39 AM
mask's Avatar
mask
fuel pump
The distrubiator is new so I probably didnt get timing right. I heard some thing like 8-10 degree BTDC. where do it reach bottom 35 deg? I´m not sure about right vaccumport on the carb
I put it on a port that pointed forward lokated under the "floter house" is that the one?
Mask. Sweden
Old May 24, 2001 | 09:54 AM
66_f100_460's Avatar
66_f100_460
fuel pump
The port for the distributor vacuum should be on the side of the carb above the throttle plate. With the vacuum at the bottom it advances all the time and could be your problem. I had that problem before. I don't know if your carb will have a vacuum above the plate are not. The only reason mine did is because I used a metering body off my old 390 holley. I am having the same problem as you right now. I will probably get back to you tomorrow.
66_f100_460 (I found out it is a 429)
Old May 24, 2001 | 05:58 PM
proud owner
fuel pump
MASK, On the holley, there will be 2 fuel bowls, or "float houses" as you seem to call them, one on front and one on back. on the left side of the holley (as you look at if from the front) there will be a little tube sticking out from next to that bowl, near the top. that is your distributor vacuum.
the tubes sticking out the bottom , UNDER the "float house", are your full-time vacuums. Do not hook your distributor up to those, they will make you run at full advance ALL the time.
66_F100, that may be your problem, but if it was running full advance all the time it would be knocking and pinging all the time instead of missing. When it misses due to timing, the timing is retarded. Just a thought, check the diaphragm on your distributor (if you havent...). Also, check the timing on the engine, and look at the timing marks when you rev the engine.. they should move significantly when you rev it.
Good luck!
J/.c
Old May 28, 2001 | 03:34 AM
mask's Avatar
mask
fuel pump
Ok, that could be the problem. I have a vacuum port on the left side of the meteringblock, I try that one
Another problem I got is that the "timing scale wheel?!?" does not match reality. when the no 1 cylinder is at TDC it´s not even on the scale! could you mont this "Wheel" wrong?
Anyway thanks for the information
Mask
Old May 28, 2001 | 03:33 PM
proud owner
fuel pump
remember, the piston comes up 2 times.. one compression, one exhaust. If you line up TDC on the "timing scale wheel", you will find that the piston IS at TDC... on the compression stroke. That is when it needs to fire. Unless you broke your crank key, then no, there is no way it can be put on wrong.
J/.c
Old May 30, 2001 | 07:48 AM
bb79ranch's Avatar
bb79ranch
fuel pump
I had the same problem on my '82 F250 4x4, I changed fuel pumps, fuel lines, filters & etc. then I finally realized it was vapor locking when it got warm/hot. Re-Routing fuel line really helped, both lines, the one from pump to carb & the one from tank to pump. If you have aftermarket exhaust & headers it gets quite close to the original located fuel lines. If possible run aluminum fuel line, it disipates heat much faster.
Todd
BB79RANCH
Old May 30, 2001 | 02:10 PM
lvstang's Avatar
lvstang
fuel pump
The Masked Rider
Jan 28, 2016 02:43 PM
The Masked Rider
Dec 19, 2015 07:54 PM
The Masked Rider
Apr 4, 2015 10:27 AM
BossFan
24
Feb 4, 2012 02:10 PM
