bosch platinum +4's
Old May 14, 2001 | 02:10 AM
mike460's Avatar
mike460
bosch platinum +4's
has anyone used bosch platinum +4's? what's your general take on them? worth the extra money? i don't know if it's relevant, but i have a set of 9mm ford motorsport wires. thanks for any info.
mike
Old May 14, 2001 | 07:47 PM
proud owner's Avatar
proud owner
bosch platinum +4's
My personal experience, the difference is not worth the money spent. I didnt notice any performance increases, and at $5.00 each versus a $.99 autolite, I found the autolite to work quite nicely! I clean, file, and gap my plugs religiously every 5,000 miles, and the Autolites work great.
The Platinums, which run for around $1.99, I have noticed to seem to stay cleaner longer when running the engine hard.. Dont know if this applies to you, but hey..
Wires.. My advice is invest in a good set. I recommend the MSD Super Conductor wires. They advertise a 50-ohm/foot resistance, and a "factory" wire is between 2000 and 5000 ohm/foot. I tested a few, and found that they are indeed 50 ohm/foot....Wow, an advertisement that was right! I noticed serious mileage gains when installed, and engine never ran better.
Good luck!
J/.c
1965 Ford Galaxie 500 (okay, so not quite a truck)
460/C6 transplant @ 389hp/491 lb.ft.
14.29@103.8, 13-14 mpg heheheheheh
Old May 15, 2001 | 11:24 AM
shami02's Avatar
shami02
bosch platinum +4's
My opinion is....
Something to think about is the Bosch platinum +4's, or any other platinum plug, will not burn up. They will keep on firing long after there is a whole in the top of your piston or other nasty things that happen when we run our engines to lean... The .99 cent Autolite will melt before other components and stop firing thus saving your piston ect. I have always felt that a good non-platinum plug (I like the Autolite) kept clean and gapped and changed regularly... Will perform just fine and you get the added insurance of a circuit breaker of sorts to protect you from sensor or computer failures and cheap gas... Comments folks?
Mike
95 F350 Dually
Old May 29, 2001 | 08:14 PM
Brakefade's Avatar
Brakefade
bosch platinum +4's
Old May 31, 2001 | 09:28 AM
Jackson's Avatar
Jackson
bosch platinum +4's
Not worth the cost. I've had a set for over a year now. At first they seemed pretty good but the little platinum electrode gets dirty quickly and caused my 460 to miss.
