what size tap??? Help
Old Feb 4, 2008 | 03:11 PM
powerstroke1869's Avatar
powerstroke1869
replacing my thermostat and snap! broke one bolt off what size tap do i need to take that other bolt out any help would be appreciated
Old Feb 4, 2008 | 05:21 PM
Cracker 73's Avatar
Cracker 73
a tap is to make sure threads are ok after you drill an use an an easy out to remove broken bolt. TO make it easier use a left handed drill bit . if no one tells you the thread type and count take one with you when you go to replace to make sure you get the ones you need and anti-seize all the new ones. Im going to dinner but can/go to shop after sushi if you need me to get you the size.
Old Feb 4, 2008 | 06:57 PM
powerstroke1869
hey thanks man for the help i got it
