I've had several ******/Jeeps in my day that I've always used my truck to trailer to trails, etc. I am now Jeepless and want to know what it would take to make my '05 STX 4x4 a capable off road machine.
My concern is the front suspension/axle. Do I need to swap in a solid front axle? I'd really like your guys' real-world opinions.
Tires, wheels, lift, lockers and winch would be next up. Thanks for your thoughts on this!
PLAN#1
78' hp d60
longfeilds if you got the $$$
i have no exp. with the aussie locker, but ive heard great reviews....so put that in the front
cut out flares
minimal lift as possible
14" fox air shocks
3 or 4link w/ panhard front
high steer
do a doubler setup with w/e tcase you have....
sterling 10.25 rear, chromos, spool
inboarded chevy 63's
traction bar setup simlar to fishy's
44" boggers
PLAN#2
2.5ton rockwells, ouverson 2" chromos
ouverson locker
full hydro
weld rear
king coilvers
triangulated 4 link f/r
evo heims
57" r2's
557ci, knarly c6, scs drop case
etc etc etc....
Thanks for the response. Are 44's the goal when it comes to tires size? Anything smaller would i be disappointed? My goal with the Jeeps was always to get 35's under them. If 44's are the target, I now have a place to start.
dude......its what you want!!!.....what tire do you want to run, what kind of wheeling do you do? what kind of driving style do you do? these will factor in to what you want to build? is this a dd as well?
Yes, dd as well. 35's on a short wheelbase jeep give plenty of clearance to handle the difficult trails. I don't need to run extreme trails by any means. I figure the longer wheel base of my truck will give me issues if I run just 35's.
I've done enough research to know that any money I put into the IFS to make it somewhat trail-worthy would be better spent on a solid front axle. Also, i want to keep the stock engine, trans, and tcase.
As to how much i want to spend...it will be a more of an on going project. I like the truck and I like to go wheeling. I need it as a dd for a couple more years anyway, so it would have to be a 'best of both worlds' build up for now. I just want to spend the money in the right places...know what i mean??
ok.....then go with
78' hp d60
14" fox coilovers
custom swaybar (look at curries for ex.)
high steer
sterling 10.25 rear, chromos, detroit locker
40" m/t of your choice
17" stazworks double beadlocks
78' hp d60
14" fox coilovers
high steer
I'd mod it a little and put some 36ish tires and wheel it like that until you get the money to buy everything else.
Since you have the leveling kit, put some cut out flares and run 35-37s and keep the stock axles until they break. The rear is a 9.75 which only has a .5" smaller ring gear than the sterling, so it should hold up to some abuse.
I wouldn't waste money on regearing unless you plan on keeping the axles and not upgrading(then go with some 4.88s or something similar), but it would be a dog with 37s and 3.55 gears(and I'm guessing its got a 4.6).
4.6 alright. Nothing wrong with it, I had the 5.4 in my 02 and I have yet to see the difference. Not a bad idea to start with tires and wheels and go from there. I'd just be worried about the IFS.
I know a couple people running 35s with no problems(most of the tires measure about 34.3" in some companys anyway), and I have some true 34" super swampers on a 04 F150 and didn't have any problems.
The 5.4 in your 02 only had stock 260 hp and somewhere around 330 ft lbs(don't quote me), and the new ones have 300 hp and 365 ft lbs, so the 02 5.4 had more power than the 4.6, and the new 5.4 has a good bit more power than the same ol' 4.6.
Should still work though, but it'll be a dog accelerating with stock gears and 35s+.
I think the bottom line is how much do you have to spend. Both of quads #1 and #2 builds are straight up best ways to do things but you are looking at 10g's+ for #1 and 20g's+ for #2. For me on a DD Id keep tires in the 35-36 range with 4.10 gears and some minor mods to engine tranny and brakes. SSRs would be good tires to get reasonable on and off road manners and miles. I dont know how much different the '97-03 F150 axle is from the '05 but I know plenty of people with 315s on their trucks. Stripping hubs is the most common thing Ive seen.
If youve got the budget you want a tire bigger than 36s and you plan to wheel hard dont waste your time with anything else than a D60 from a 78-79 F250. Leaf springs would be cheapest but coilovers and a 4link would be best.
hes wanting to wheel.....the ifs just isn't going to cut it......i still vote d60 even if you dont do any of the other stuff i said....he said its a work in progress, so you might as well do the best possible so when your done, you wont have to re-upgrade parts...
