One fouled plug
Old Feb 4, 2008 | 12:37 PM
bertha66's Avatar
bertha66
One fouled plug
My 66 F100 4x4, I run a 67 Flairlane 390 GT engine, engine has been in the truck sense 1979. At that time the engine was freshened up with rings and bearings and a valve grind, notting else. this last 2-3 years I have been having a problem with the #5 plug fouling out. 2 weeks ago I changed the points, condenser, the rotor, cap, plug wires and the plugs. Dist, was replaced with a rebuilt one a couple of years ago. It was still not running very good, checked firing and #5 was not firing. I changed the plug wire from #6 to #5 and check it again, #5 still not firing. I changed out the coil and #5 started firing. Lasted 1 week, yesterday no fire in #5. Switched #6 plug to #5 and #5 to #6 hole, firing just fine again, in both. Timing is set at 8 degress, carb is Elderbrock, compression is 125lbs, plugs are #45 Motocraft, and I'm getting a pinging after the truck is warmed up and driven 10-12 miles. Any ideas on what is doing this, I would love to hear.
Thanks
Old Feb 4, 2008 | 02:25 PM
blue68f100's Avatar
blue68f100
It almost sounds like the plug is not getting a ground or opened up internally. As far as pinging try backing off the timing a couple of deg. Engine may be getting carboned up, try some cleaner or give it a drink of water.
Old Feb 4, 2008 | 09:38 PM
Hypoid's Avatar
Hypoid
Cheap gas???
It seems there have been a flurry of complaints this winter. I didn't bookmark the post, but I did read mention of winter-blend fuel causing detonation.
Are you using any fuel additives? After I started running a lead substitute, I noticed detergent fouling on my plugs.
Old Feb 5, 2008 | 01:55 AM
Bear 45/70's Avatar
Bear 45/70
Sounds like you may have lost a valve seal on #5. Try going one or two heat ranges hotter on the plug in #5.
Old Feb 5, 2008 | 10:05 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
What is the plug fouled with? Oil or gas?
If it's oil, I'm betting on an intake leak after the freshening up, sucking oil into the cylinder (in a big way). Either that, or your valve guides were knurled and one wore out very fast (knurling doesn't last long).
Also, another thing to check, key on, engine not running, check the voltage at the + side of the coil, and ground the meter to the battery (-). Report back.
And one more thing, check the cam in the distributor that makes the points open and close. Make sure it's not worn. Also, with the points both closed, and open, pull on the rotor back and forth in the direction of the points. If they open and close when you do this, you need to replace the distributor (or the top bushing). Sometimes, rebuilt distributors don't get a new bushing on top, and they do wear out with points. Or, convert to electronic if the bushing is shot, it won't matter anymore
Old Feb 5, 2008 | 11:17 AM
bertha66's Avatar
bertha66
The plug fouls with black carbon, dry shooty looking. I run Shell 93 octane gas, with no additives. I did change the dist. with the rebuilt one that's in my 428 Galaxie, did not seem to make any differance. I will check the coil, but it will have to wait untill this weekend, my wife is driving it to work and we both don't get home untill after dark. I'm going to try decarboning it this weekend and put in some octane boost.
Thanks for the ideas, it is a real help.
Old Feb 6, 2008 | 08:22 AM
krewat's Avatar
krewat
Dry black carbon is gas. I wonder if you have a float leak in the carb and it's flooding out? (been a long time since I looked at an FE intake - not sure if #5 would be the first one to fill).
Old Feb 7, 2008 | 09:05 PM
Hypoid's Avatar
Hypoid
Hmmm, #5 sits up front, shares the plenum with #s 2, 3, & 8. You would think that fuel would run to #8 before any others. Do you park the truck with the nose pointed down-hill?
I don't know the Ebocks, but the one I have on the bench has fuel bowls on the sides. I guess it would be possible for the driver's side to leak, maybe run too rich?
Maybe I have it backwards. Could the other plenum be too lean and covering up a weak spark?
Before you blow out the carbon, pull all the plugs and look at them in terms of intake plenum grouping. Maybe one set is a tad darker than the other, with #5 being the worst.
Old Feb 8, 2008 | 01:19 PM
bertha66's Avatar
bertha66
The Truck sits in the shop, floor is flat. When I replaced the plugs 3weeks ago #5 was the only one that was black, others were grayish. Last weekend I pulled #5, it was black and pulled #6, it was clean and switched them and have been running it all week, #5 is still misfiring.
Old Feb 11, 2008 | 12:43 PM
bertha66's Avatar
bertha66
I ran some Seafoam in the carb yesterday, when I got done #5 was firing good. Looks like it was carbon build up. I will see how it goes as I drive it. Thanks for all the hepful post.
EwagonJeff
Modular V8 (4.6L, 5.4L)
Apr 6, 2017 02:07 AM
Mark Everett
Oct 29, 2016 02:01 PM
srg8268
Jan 19, 2015 11:51 AM
mikejaros
Oct 6, 2011 01:30 AM
06'Scab
2004 - 2008 F150
19
Mar 31, 2011 09:37 PM
