no start
Old Feb 3, 2008 | 11:39 PM
bri74's Avatar
bri74
no start
I am having troubles.... No start it fires once or twice then just cranks for a bit then another fire but nothing continuous? Had a NO.1 inj code changed injector but still the same cant keep it running long enough to do a KOER test. Dont know whats up? 04 6.0 130k mi. runs in very very cold environment
Old Feb 3, 2008 | 11:45 PM
brickie's Avatar
brickie
Time for glow plugs I guess.Is there a thick stinky white cloud when she is trying to start?
Old Feb 4, 2008 | 12:18 AM
bri74's Avatar
bri74
No white smoke. Just found another code its Fuel Injection control module
Old Feb 4, 2008 | 12:44 AM
brickie's Avatar
brickie
There where wire chafing issues in 03-04 check the harness on the top of the motor near all the studs and also where it is routed across the valley next to the fuel oil filters.
Old Feb 4, 2008 | 01:22 AM
bri74's Avatar
bri74
cool checking it now but where is the FICM located is it above the drivers side valve cover?
Old Feb 4, 2008 | 01:27 AM
LvTitan's Avatar
LvTitan
call the dealer and give them your VIN# have them check the oasis report and see if your truck has had all of the TSB's (technical service bulletin, fancy word for recall) done to it..
there definitely was a wiring harness upgrade recall for the FICM. this is mounted on your driver side valve cover. about the size of paperback book, should be silver with heat sink fins on it. there is also your crank case vent filter on your driver side valve cover it's a black plastic box.
http://www.backglass.org/duncan/ps60_manual/ps60_065.jpg
the above link is page 65 of the 6liter bible, if it's too small to read, move the pointer over the page for a second, and a box will popup near the bottom, click on this and it will enlarge the page for ease of reading. hope this helps..
Old Feb 4, 2008 | 01:41 AM
brickie's Avatar
brickie
I found what I was looking for.Broadcast message 0918/1374 wiring Harness Chafing.Some 03/04 trucks may exhibit a crank/no start,rough running,misfire,buck jerk or lack of power.This may be due to FICM harness chafing on a valve cover stud near the FICM.Other potential locations for chafing are where the harness routs past the EBP sensor.The belt ideler on the drivers side of the engine,the glow plug control module bracket on the passengers side of the engine and the accelerator pedal sensor wires at the steering colum(adjustable pedals only).Rerout and repair harness as necessarry.
Old Feb 4, 2008 | 01:42 AM
bri74's Avatar
bri74
hey thanks alot I found the rear plug on the FICM is loose so digging deeper into that.
