Sponsored by: Auxito
misfire in 3
Old Feb 3, 2008 | 07:05 PM
daxelson's Avatar
daxelson
misfire in 3
I have a ford f150 with a 4.6l. code reader tells misfire in 1 and 3 replaced all plugs, went to misfire in 3. checked wire for 3, looks good has resistance, checked coil, testing to specs acording to my repair manual. what else can i check?
Old Feb 4, 2008 | 10:49 AM
KingRanchMan02's Avatar
KingRanchMan02
Welcome to FTE daxelson!
How many miles on the truck? Do you know if the spark plug wires are original equipment wires? What kind of spark plugs did you use? Good luck!
Old Feb 4, 2008 | 06:18 PM
daxelson's Avatar
daxelson
I got about 1 yr/20000 mi on these plugs and wires, put new autolite xp iridium plugs in according to oriley parts guy is what book calls for. the old plug in number 3 had ceramic broken around eletrode but no other damage to it
Old Feb 4, 2008 | 09:13 PM
daxelson's Avatar
daxelson
just did a visual spark check, saw arc from number 1 but not 3, fixed that, pulled 1 and 3 plugs, everything looked good, swaped fuel injectors 1 and 3, erased codes, took it for a drive got same p0303 code
Old Feb 4, 2008 | 10:19 PM
superdutymj's Avatar
superdutymj
how much resistance did the #3 wire have?
Old Feb 5, 2008 | 09:39 AM
KingRanchMan02
Can you say "Replace the coil"?
Old Feb 9, 2008 | 09:58 AM
daxelson's Avatar
daxelson
swaped coils and changed out the wire, pulled the plug and found no compression in the 3 cylinder, good compression in the others, thinking now bad valve. looked for antifreeze leak for cracked head or bad head gasket, nothing. will be pulling off valve cover next.
SuperSnake
Nov 30, 2007 07:27 PM
barnbridge
Nov 11, 2007 09:49 AM
yamaguy
Jun 29, 2007 06:31 PM
Shane07XLT
2004 - 2008 F150
Mar 6, 2007 07:29 AM
